Zabbix not pulling Data from SNMP OID
  • markosa
    • Aug 2022
    • 107
    #16
    Are you using with snmpget, this: 1.3.6.1.2.1.10.94.1.1.5.1.2.550 or this: .1.3.6.1.2.1.10.94.1.1.5.1.2.550 ? You see small difference there? You are using form of later one with walk...
    • LukeAB93UK
      • Jun 2023
      • 72
      #17
      [@zabbixproxy02 ~]$ snmpwalk -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2
      SNMPv2-SMI::transmission.94.1.1.5.1.2.550 = Gauge32: 8544000
      [@zabbixproxy02 ~]$ snmpwalk -v2c -c <Community> <IP> 1.3.6.1.2.1.10.94.1.1.5.1.2
      Both of them work.
      However if i append either with .550 I get SNMPv2-SMI::transmission.94.1.1.5.1.2.550 = No Such Instance currently exists at this OID
      If I then try to SNMP get with either string and both with and without .550 on the end all I get back is this
      [@rts-th-zabbixproxy02 ~]$ snmpget -v2c -c <Community> <IP> 1.3.6.1.2.1.10.94.1.1.5.1.2
      SNMPv2-SMI::transmission.94.1.1.5.1.2 = No Such Instance currently exists at this OID
      [@rts-th-zabbixproxy02 ~]$ snmpget -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2
      [@rts-th-zabbixproxy02 ~]$ snmpget -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2.550
      [@rts-th-zabbixproxy02 ~]$ snmpget -v2c -c <Community> <IP> 1.3.6.1.2.1.10.94.1.1.5.1.2.550
      • markosa
        • Aug 2022
        • 107
        #18
        And you tried also : snmpget -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2.550.0 ? snmpwalk and snmpget work bit differently, there's also snmpgetnext which works like snmpwalk but with exact OID.
        • LukeAB93UK
          • Jun 2023
          • 72
          #19
          Hey There,
          So I ran that exact string and I also run snmpgetnext
          [@rts-th-zabbixproxy02 ~]$ snmpgetnext -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2.550
          SNMPv2-SMI::transmission.94.1.1.6.1.1.550 = Counter32: 0
          SNMPv2-SMI::transmission.94.1.1.5.1.2.550 = Gauge32: 22191000
          [@rts-th-zabbixproxy02 ~]$ snmpgetnext -v2c -c <Community> <IP> .1.3.6.1.2.1.10.94.1.1.5.1.2.550.0
          • rickypr
            • Oct 2024
            I ended up here after googling for this problem. I had the same problem with an OID that has an IP address in it. After struggling wiith this for a while I figured out that snmpget did not send the request, tcpdump showed that clearly. I then edited /etc/snmp/snmp.conf and removed loading all mibs. After doing that snmpget sent the request and retrieved the OID successfully. I still have to figure out why loading, in my case the Juniper MIB, prevents it to retrieve that OID. After I stopped loading all MIBs snmpget retrieved the value fine and after restarting zabbix-server, it started retrieving those values correclty.
            I just wanted to share this information, if I figure out what happens with the MIB I will share it here.
