Huawei S5700 series device with SNMPv3 on Zabbix
  • emrecck
    • Jun 2023
    Hi Team,
    I need your help with the Huawei S5700 series switch monitoring with SNMPv3. I add my Huawei S5700 series device with SNMPv3 on Zabbix. Meanwhile, I am using the Huawei template downloaded from the Zabbix template page and I tried more than one template at different times. The SNMP icon is always red and gives "Timeout" or "Unknown Username" warnings. I couldn't find a solution to any of the problems found in the forum. Parameters are entered correctly. In addition, when I connect different network devices via SNMP, the SNMP icon appears green and data collection is successful. I am forwarding the configuration on the switch to you below. I need your help ASAP. Thank you for your attention.
    Zabbix Huawei Template Names:
    • Huawei_SNMP
    • Huawei VRP by SNMP
    • Huawei OceanStor 5300 V5 by SNMP
    Huawei S5700 Switch Configuration:
    snmp-agent
    snmp-agent local-engineid "---*---*---*---"
    snmp-agent sys-info version v3
    snmp-agent group v3 v3group privacy read-view isoview write-view isoview notify-view isoview
    snmp-agent target-host trap address udp-domain 192.168.1.10 params securityname test123 v3 privacy
    snmp-agent mib-view included isoview iso
    snmp-agent usm-user v3 test123
    snmp-agent usm-user v3 test123 group v3group
    snmp-agent usm-user v3 test123 authentication-mode sha cipher pass123
    snmp-agent usm-user v3 test123 privacy-mode aes128 cipher pass123
    snmp-agent protocol source-status all-interface
    snmp-agent protocol source-status ipv6 all-interface​
  • anpanbarb
    • Feb 2024
    Hello! I have the same problem, how did you solve it?
    thanks
    • jothoma1
      • Apr 2025
      same problem for us
      if someone knows how to solve
      thanks
