Iptables monitoring and triggers
  • rbelsch
    • Apr 2023
    I am attempting to monitor changes to IPTables on a host. I have created the following Item:
    vfs.file.cksum[/etc/iptables/rules.v4] (this does show in my graphs any change that happens to IPTables on the test host.
    But the Trigger isn't working which I have defined as:
    (last(/sbc-testing-2/vfs.file.cksum[/etc/iptables/rules.v4],#1)<>last(/sbc-testing-2/vfs.file.cksum[/etc/iptables/rules.v4],#2))>0
    I have been digging into the forums and have been unable to find a solution to this.
    The other Question I have which also unable to find a solution to:
    We would like to be able to display what change was done on IPTables on the Trigger output if possible or another Trigger to display the change.
    that is strange triger expression... a<>b>0 ?? there is a change() function for that
    change (/host/key)
    The amount of difference between the previous and latest value. Supported value types: float, int, str, text, log
    For strings returns:
    0 - values are equal
    1 - values differ
    Example:
    => change(/host/key)>10
    Numeric difference will be calculated, as seen with these incoming example values ('previous' and 'latest' value = difference):
    '1' and '5' = +4
    '3' and '1' = -2
    '0' and '-2.5' = -2.5
    See also: abs for comparison
    To display a change, you need at first capture the change... That would probably require completely different checking...
