Zabbix and Veeam
  • JackoAC
    • May 2023
    • 35
    Zabbix and Veeam
    I'm running Zabbix 6.0.17 and I'd like to monitor my Veeam Standard edition v11 server.
    In the Zabbix documentation it says that I need the URL API of my Veeam server,
    Is there any other way to monitor the status of Veeam jobs? with another template or something?
    Do you know where I can find this URL?
    Thanks in advance.​
  • Answer selected by JackoAC at 07-07-2023, 12:04.
    JackoAC
    • May 2023
    • 35
    For people wanting to do it with eventlog,
    Here is how i configured my item to get the failed backup job.
    Veeam Backup = the name in the eventlog
    Error = type of log i want to get
    Veeam MP = source of log
    190 = ID of the event
    And with the trigger
    I can see which backup is failed in latest data.
    i just need to see how to get the name of the failed backup in the trigger.
    • Hamardaban
      • May 2019
      • 2714
      • JackoAC
        JackoAC commented
        I followed your link and arrived on your post.
        However, when I try to import your template, it gives an error.
        "Wrong version" when i change it,
        "Wrong name and template" when i change it,
        "Wrong OID", do you know why ?
        Thanks in advance
    • PeterZielony
      • Nov 2022
      • 146
      Standard doesnt have api support?
      Url more likely to be https://<veeam.host>:9419
      Hiring in the UK? Drop a message
      • JackoAC
        JackoAC commented
        Hello, i've asked the support for the information and yes the standard doesnt have API support
    • PeterZielony
      • Nov 2022
      • 146
      You have 3x choices really
      - collect info via windows event log
      - collect info from produced logs (not my fav)
      - collect info from database (veeam comes with mssql - but again not sure if standard got one) directly to get status - cannot answer from which table but im in process of investigating and creating non standard views in sql to collect all info i need (im using api and it doesnt show status of replication via api for some reason, only backups)
      • JackoAC
        JackoAC commented
        Well go i'll try with the event log, thanks for your answer.
        I'm not sure about going into the database.
    • Hamardaban
      • May 2019
      • 2714
      Unfortunately I don't have time to fix it.
      The template is made for version 6.2
      There is nothing complicated in it - you can look into its text, understand the idea and make your own template.
      • JackoAC
        JackoAC commented
        I won't hide my sadness x)
        I'll try to understand and to make it work, thanks for your help
    • JackoAC
      • May 2023
      • 35
      • JackoAC
        • May 2023
        • 35
        I have a problem with this alert, the alert is included in the last data, I retrieve the data but the trigger does not appear on the dashboard, while it appeared before.
        Click image for larger version  Name:	image.png Views:	1 Size:	4.8 KB ID:	466561
        On the dashborard im supposed to see "SRV35-BKP - trigger...." but i dont see it
        Do you have any idea?
        Thanks in advance​.
        • JackoAC
          JackoAC commented
          idk why but now its ok
