Issue with Zabbix proxy service turning off and missing data for items
  • Maissa DRIDI
    • Apr 2023
    • 13
    I have encountered a problem with my Zabbix setup, and I would appreciate some assistance in resolving it. Here's the issue I am facing:
    I have a Zabbix proxy server monitoring 182 hosts. Initially, everything was working fine, but recently I started experiencing the following problem:
    The Zabbix server repeatedly shows the error message: "Zabbix server: More than 100 items having missing data for more than 10 minutes."
    As a result of this error, the Zabbix proxy service turns off automatically and does not restart on its own.
    To get the proxy service running again, I have to manually restart the entire proxy machine.
    This issue is causing interruptions in monitoring and affecting the data collection process. I would like to understand the root cause of this problem and find a resolution.
    Here are some additional details about my setup:
    Number of monitored hosts: 182
    Zabbix server version: 6.4
    Zabbix proxy version: 6.4
    Proxy machine specifications:
    OS : Ubuntu 22.04
    Disque : 80 GB
    RAM : 4 GB
    CPU : 2 vCPU​
    ProxyMode: active
    I have already checked the following:
    Proxy configuration: The proxy configuration seems to be correct and matches the settings on the Zabbix server.
    Network connectivity: There are no network issues, and the proxy can reach the Zabbix server without any problem.
    Maybe it is the other way around... first your proxy dies in some reason and then you will get notifications, that there is a delay in data ?
    Anything in proxy logs ? Or in server logs?
    • Maissa DRIDI
      • Apr 2023
      • 13
      Yes first the proxy dies, and then I get notifications.
      No there is nothing in the proxy logs or the server logs.​
