I am new to Zabbix and this is my first install.
While following the instructions, I am stuck with mysql: Command not found step.
Below are the commands run so far. Any suggestions are appreciated.
[root@acsmonitoring ~]# rpm -ivh http://repo.zabbix.com/zabbix/3.0/rh...el7.noarch.rpm
Retrieving http://repo.zabbix.com/zabbix/3.0/rh...el7.noarch.rpm
warning: /var/tmp/rpm-tmp.Vu2pCg: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
Preparing... ################################# [100%]
Updating / installing...
1:zabbix-release-3.0-1.el7 ################################# [100%]
[root@acsmonitoring ~]# yum install zabbix-server-mysql zabbix-web-mysql
Loaded plugins: fastestmirror
base | 3.6 kB 00:00
extras | 3.4 kB 00:00
updates | 3.4 kB 00:00
zabbix | 951 B 00:00
zabbix-non-supported | 951 B 00:00
(1/4): extras/7/x86_64/primary_db | 149 kB 00:00
(2/4): base/7/x86_64/group_gz | 155 kB 00:01
(3/4): updates/7/x86_64/primary_db | 5.7 MB 00:01
(4/4): base/7/x86_64/primary_db | 5.3 MB 00:03
(1/2): zabbix/x86_64/primary | 9.6 kB 00:00
(2/2): zabbix-non-supported/x86_64/primary | 1.6 kB 00:00
Determining fastest mirrors
* base: mirror.oss.ou.edu
* extras: mirrors.sonic.net
* updates: centos.host-engine.com
zabbix 66/66
zabbix-non-supported 4/4
Resolving Dependencies
--> Running transaction check
---> Package zabbix-server-mysql.x86_64 0:3.0.4-1.el7 will be installed
--> Processing Dependency: fping for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
--> Processing Dependency: libiksemel.so.3()(64bit) for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
--> Processing Dependency: libnetsnmp.so.31()(64bit) for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
--> Processing Dependency: libOpenIPMIposix.so.0()(64bit) for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
--> Processing Dependency: libodbc.so.2()(64bit) for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
--> Processing Dependency: libOpenIPMI.so.0()(64bit) for package: zabbix-server-mysql-3.0.4-1.el7.x86_64
---> Package zabbix-web-mysql.noarch 0:3.0.4-1.el7 will be installed
--> Processing Dependency: zabbix-web = 3.0.4-1.el7 for package: zabbix-web-mysql-3.0.4-1.el7.noarch
--> Processing Dependency: php-mysql for package: zabbix-web-mysql-3.0.4-1.el7.noarch
---> Package OpenIPMI-libs.x86_64 0:2.0.19-11.el7 will be installed
--> Processing Dependency: OpenIPMI-modalias = 2.0.19-11.el7 for package: OpenIPMI-libs-2.0.19-11.el7.x86_64
---> Package fping.x86_64 0:3.10-1.el7 will be installed
---> Package iksemel.x86_64 0:1.4-2.el7.centos will be installed
---> Package net-snmp-libs.x86_64 1:5.7.2-24.el7_2.1 will be installed
---> Package php-mysql.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
--> Processing Dependency: php-pdo(x86-64) = 5.4.16-36.1.el7_2.1 for package: php-mysql-5.4.16-36.1.el7_2.1.x86_64
---> Package unixODBC.x86_64 0:2.3.1-11.el7 will be installed
--> Processing Dependency: libltdl.so.7()(64bit) for package: unixODBC-2.3.1-11.el7.x86_64
---> Package zabbix-web.noarch 0:3.0.4-1.el7 will be installed
--> Processing Dependency: php >= 5.4 for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: php-gd for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: php-mbstring for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: dejavu-sans-fonts for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: php-bcmath for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: httpd for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: php-ldap for package: zabbix-web-3.0.4-1.el7.noarch
--> Processing Dependency: php-xml for package: zabbix-web-3.0.4-1.el7.noarch
---> Package OpenIPMI-modalias.x86_64 0:2.0.19-11.el7 will be installed
---> Package dejavu-sans-fonts.noarch 0:2.33-6.el7 will be installed
--> Processing Dependency: dejavu-fonts-common = 2.33-6.el7 for package: dejavu-sans-fonts-2.33-6.el7.noarch
---> Package httpd.x86_64 0:2.4.6-40.el7.centos.4 will be installed
--> Processing Dependency: httpd-tools = 2.4.6-40.el7.centos.4 for package: httpd-2.4.6-40.el7.centos.4.x86_64
--> Processing Dependency: /etc/mime.types for package: httpd-2.4.6-40.el7.centos.4.x86_64
--> Processing Dependency: libaprutil-1.so.0()(64bit) for package: httpd-2.4.6-40.el7.centos.4.x86_64
--> Processing Dependency: libapr-1.so.0()(64bit) for package: httpd-2.4.6-40.el7.centos.4.x86_64
---> Package libtool-ltdl.x86_64 0:2.4.2-21.el7_2 will be installed
---> Package php.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
--> Processing Dependency: php-common(x86-64) = 5.4.16-36.1.el7_2.1 for package: php-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: php-cli(x86-64) = 5.4.16-36.1.el7_2.1 for package: php-5.4.16-36.1.el7_2.1.x86_64
---> Package php-bcmath.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
---> Package php-gd.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
--> Processing Dependency: libpng15.so.15(PNG15_0)(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libjpeg.so.62(LIBJPEG_6.2)(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libt1.so.5()(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libpng15.so.15()(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libjpeg.so.62()(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libXpm.so.4()(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libX11.so.6()(64bit) for package: php-gd-5.4.16-36.1.el7_2.1.x86_64
---> Package php-ldap.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
---> Package php-mbstring.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
---> Package php-pdo.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
---> Package php-xml.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.24)(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.13)(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libxslt.so.1()(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
--> Processing Dependency: libexslt.so.0()(64bit) for package: php-xml-5.4.16-36.1.el7_2.1.x86_64
---> Package apr.x86_64 0:1.4.8-3.el7 will be installed
---> Package apr-util.x86_64 0:1.5.2-6.el7 will be installed
---> Package dejavu-fonts-common.noarch 0:2.33-6.el7 will be installed
--> Processing Dependency: fontpackages-filesystem for package: dejavu-fonts-common-2.33-6.el7.noarch
---> Package httpd-tools.x86_64 0:2.4.6-40.el7.centos.4 will be installed
---> Package libX11.x86_64 0:1.6.3-2.el7 will be installed
--> Processing Dependency: libX11-common >= 1.6.3-2.el7 for package: libX11-1.6.3-2.el7.x86_64
--> Processing Dependency: libxcb.so.1()(64bit) for package: libX11-1.6.3-2.el7.x86_64
---> Package libXpm.x86_64 0:3.5.11-3.el7 will be installed
---> Package libjpeg-turbo.x86_64 0:1.2.90-5.el7 will be installed
---> Package libpng.x86_64 2:1.5.13-7.el7_2 will be installed
---> Package libxslt.x86_64 0:1.1.28-5.el7 will be installed
---> Package mailcap.noarch 0:2.1.41-2.el7 will be installed
---> Package php-cli.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
---> Package php-common.x86_64 0:5.4.16-36.1.el7_2.1 will be installed
--> Processing Dependency: libzip.so.2()(64bit) for package: php-common-5.4.16-36.1.el7_2.1.x86_64
---> Package t1lib.x86_64 0:5.1.2-14.el7 will be installed
---> Package fontpackages-filesystem.noarch 0:1.44-8.el7 will be installed
---> Package libX11-common.noarch 0:1.6.3-2.el7 will be installed
---> Package libxcb.x86_64 0:1.11-4.el7 will be installed
--> Processing Dependency: libXau.so.6()(64bit) for package: libxcb-1.11-4.el7.x86_64
---> Package libzip.x86_64 0:0.10.1-8.el7 will be installed
---> Package libXau.x86_64 0:1.0.8-2.1.el7 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
zabbix-server-mysql x86_64 3.0.4-1.el7 zabbix 1.7 M
zabbix-web-mysql noarch 3.0.4-1.el7 zabbix 4.0 k
Installing for dependencies:
OpenIPMI-libs x86_64 2.0.19-11.el7 base 501 k
OpenIPMI-modalias x86_64 2.0.19-11.el7 base 15 k
apr x86_64 1.4.8-3.el7 base 103 k
apr-util x86_64 1.5.2-6.el7 base 92 k
dejavu-fonts-common noarch 2.33-6.el7 base 64 k
dejavu-sans-fonts noarch 2.33-6.el7 base 1.4 M
noarch 1.44-8.el7 base 9.9 k
fping x86_64 3.10-1.el7 zabbix-non-supported 40 k
httpd x86_64 2.4.6-40.el7.centos.4 updates 2.7 M
httpd-tools x86_64 2.4.6-40.el7.centos.4 updates 83 k
iksemel x86_64 1.4-2.el7.centos zabbix-non-supported 49 k
libX11 x86_64 1.6.3-2.el7 base 605 k
libX11-common noarch 1.6.3-2.el7 base 162 k
libXau x86_64 1.0.8-2.1.el7 base 29 k
libXpm x86_64 3.5.11-3.el7 base 54 k
libjpeg-turbo x86_64 1.2.90-5.el7 base 134 k
libpng x86_64 2:1.5.13-7.el7_2 updates 213 k
libtool-ltdl x86_64 2.4.2-21.el7_2 updates 49 k
libxcb x86_64 1.11-4.el7 base 189 k
libxslt x86_64 1.1.28-5.el7 base 242 k
libzip x86_64 0.10.1-8.el7 base 48 k
mailcap noarch 2.1.41-2.el7 base 31 k
net-snmp-libs x86_64 1:5.7.2-24.el7_2.1 updates 747 k
php x86_64 5.4.16-36.1.el7_2.1 updates 1.4 M
php-bcmath x86_64 5.4.16-36.1.el7_2.1 updates 56 k
php-cli x86_64 5.4.16-36.1.el7_2.1 updates 2.7 M
php-common x86_64 5.4.16-36.1.el7_2.1 updates 563 k
php-gd x86_64 5.4.16-36.1.el7_2.1 updates 126 k
php-ldap x86_64 5.4.16-36.1.el7_2.1 updates 51 k
php-mbstring x86_64 5.4.16-36.1.el7_2.1 updates 503 k
php-mysql x86_64 5.4.16-36.1.el7_2.1 updates 99 k
php-pdo x86_64 5.4.16-36.1.el7_2.1 updates 97 k
php-xml x86_64 5.4.16-36.1.el7_2.1 updates 124 k
t1lib x86_64 5.1.2-14.el7 base 166 k
unixODBC x86_64 2.3.1-11.el7 base 413 k
zabbix-web noarch 3.0.4-1.el7 zabbix 3.4 M
Transaction Summary
Install 2 Packages (+36 Dependent packages)
Total download size: 19 M
Installed size: 79 M
Is this ok [y/d/N]: y
Downloading packages:
(1/38): OpenIPMI-modalias-2.0.19-11.el7.x86_64.rpm | 15 kB 00:00
(2/38): apr-1.4.8-3.el7.x86_64.rpm | 103 kB 00:00
(3/38): OpenIPMI-libs-2.0.19-11.el7.x86_64.rpm | 501 kB 00:00
(4/38): apr-util-1.5.2-6.el7.x86_64.rpm | 92 kB 00:00
(5/38): dejavu-fonts-common-2.33-6.el7.noarch.rpm | 64 kB 00:00
warning: /var/cache/yum/x86_64/7/zabbix-non-supported/packages/fping-3.10-1.el7.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
Public key for fping-3.10-1.el7.x86_64.rpm is not installed
(6/38): fping-3.10-1.el7.x86_64.rpm | 40 kB 00:00
(7/38): fontpackages-filesystem-1.44-8.el7.noarch.rpm | 9.9 kB 00:00
(8/38): iksemel-1.4-2.el7.centos.x86_64.rpm | 49 kB 00:00
(9/38): httpd-tools-2.4.6-40.el7.centos.4.x86_64.rpm | 83 kB 00:00
(10/38): libX11-common-1.6.3-2.el7.noarch.rpm | 162 kB 00:00
(11/38): libXpm-3.5.11-3.el7.x86_64.rpm | 54 kB 00:00
(12/38): libXau-1.0.8-2.1.el7.x86_64.rpm | 29 kB 00:00
(13/38): httpd-2.4.6-40.el7.centos.4.x86_64.rpm | 2.7 MB 00:00
(14/38): libtool-ltdl-2.4.2-21.el7_2.x86_64.rpm | 49 kB 00:00
(15/38): libjpeg-turbo-1.2.90-5.el7.x86_64.rpm | 134 kB 00:00
(16/38): libpng-1.5.13-7.el7_2.x86_64.rpm | 213 kB 00:00
(17/38): libX11-1.6.3-2.el7.x86_64.rpm | 605 kB 00:00
(18/38): libxslt-1.1.28-5.el7.x86_64.rpm | 242 kB 00:00
(19/38): dejavu-sans-fonts-2.33-6.el7.noarch.rpm | 1.4 MB 00:00
(20/38): net-snmp-libs-5.7.2-24.el7_2.1.x86_64.rpm | 747 kB 00:00
(21/38): php-bcmath-5.4.16-36.1.el7_2.1.x86_64.rpm | 56 kB 00:00
(22/38): mailcap-2.1.41-2.el7.noarch.rpm | 31 kB 00:00
(23/38): libzip-0.10.1-8.el7.x86_64.rpm | 48 kB 00:00
(24/38): php-cli-5.4.16-36.1.el7_2.1.x86_64.rpm | 2.7 MB 00:00
(25/38): libxcb-1.11-4.el7.x86_64.rpm | 189 kB 00:00
(26/38): php-common-5.4.16-36.1.el7_2.1.x86_64.rpm | 563 kB 00:00
(27/38): php-gd-5.4.16-36.1.el7_2.1.x86_64.rpm | 126 kB 00:00
(28/38): php-ldap-5.4.16-36.1.el7_2.1.x86_64.rpm | 51 kB 00:00
(29/38): php-5.4.16-36.1.el7_2.1.x86_64.rpm | 1.4 MB 00:00
(30/38): php-mbstring-5.4.16-36.1.el7_2.1.x86_64.rpm | 503 kB 00:00
(31/38): php-mysql-5.4.16-36.1.el7_2.1.x86_64.rpm | 99 kB 00:00
(32/38): php-pdo-5.4.16-36.1.el7_2.1.x86_64.rpm | 97 kB 00:00
(33/38): php-xml-5.4.16-36.1.el7_2.1.x86_64.rpm | 124 kB 00:00
Public key for zabbix-server-mysql-3.0.4-1.el7.x86_64.rpm is not installed
(34/38): zabbix-server-mysql-3.0.4-1.el7.x86_64.rpm | 1.7 MB 00:00
(35/38): zabbix-web-mysql-3.0.4-1.el7.noarch.rpm | 4.0 kB 00:00
(36/38): t1lib-5.1.2-14.el7.x86_64.rpm | 166 kB 00:00
(37/38): unixODBC-2.3.1-11.el7.x86_64.rpm | 413 kB 00:00
(38/38): zabbix-web-3.0.4-1.el7.noarch.rpm | 3.4 MB 00:04
Total 2.8 MB/s | 19 MB 00:06
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX
Importing GPG key 0x79EA5ED4:
Userid : "Zabbix SIA <[email protected]>"
Fingerprint: fbab d5fb 2025 5eca b22e e194 d13d 58e4 79ea 5ed4
Package : zabbix-release-3.0-1.el7.noarch (installed)
Is this ok [y/N]: y
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
Installing : apr-1.4.8-3.el7.x86_64 1/38
Installing : apr-util-1.5.2-6.el7.x86_64 2/38
Installing : httpd-tools-2.4.6-40.el7.centos.4.x86_64 3/38
Installing : 1:net-snmp-libs-5.7.2-24.el7_2.1.x86_64 4/38
Installing : libzip-0.10.1-8.el7.x86_64 5/38
Installing : php-common-5.4.16-36.1.el7_2.1.x86_64 6/38
Installing : php-ldap-5.4.16-36.1.el7_2.1.x86_64 7/38
Installing : php-bcmath-5.4.16-36.1.el7_2.1.x86_64 8/38
Installing : php-mbstring-5.4.16-36.1.el7_2.1.x86_64 9/38
Installing : php-pdo-5.4.16-36.1.el7_2.1.x86_64 10/38
Installing : php-mysql-5.4.16-36.1.el7_2.1.x86_64 11/38
Installing : php-cli-5.4.16-36.1.el7_2.1.x86_64 12/38
Installing : iksemel-1.4-2.el7.centos.x86_64 13/38
Installing : libXau-1.0.8-2.1.el7.x86_64 14/38
Installing : libxcb-1.11-4.el7.x86_64 15/38
Installing : libxslt-1.1.28-5.el7.x86_64 16/38
Installing : php-xml-5.4.16-36.1.el7_2.1.x86_64 17/38
Installing : libtool-ltdl-2.4.2-21.el7_2.x86_64 18/38
Installing : unixODBC-2.3.1-11.el7.x86_64 19/38
Installing : libX11-common-1.6.3-2.el7.noarch 20/38
Installing : libX11-1.6.3-2.el7.x86_64 21/38
Installing : t1lib-5.1.2-14.el7.x86_64 22/38
Installing : libXpm-3.5.11-3.el7.x86_64 23/38
Installing : mailcap-2.1.41-2.el7.noarch 24/38
Installing : httpd-2.4.6-40.el7.centos.4.x86_64 25/38
Installing : php-5.4.16-36.1.el7_2.1.x86_64 26/38
Installing : OpenIPMI-modalias-2.0.19-11.el7.x86_64 27/38
Installing : OpenIPMI-libs-2.0.19-11.el7.x86_64 28/38
Installing : fontpackages-filesystem-1.44-8.el7.noarch 29/38
Installing : dejavu-fonts-common-2.33-6.el7.noarch 30/38
Installing : dejavu-sans-fonts-2.33-6.el7.noarch 31/38
Installing : 2:libpng-1.5.13-7.el7_2.x86_64 32/38
Installing : libjpeg-turbo-1.2.90-5.el7.x86_64 33/38
Installing : php-gd-5.4.16-36.1.el7_2.1.x86_64 34/38
Installing : zabbix-web-mysql-3.0.4-1.el7.noarch 35/38
Installing : zabbix-web-3.0.4-1.el7.noarch 36/38
Installing : fping-3.10-1.el7.x86_64 37/38
Installing : zabbix-server-mysql-3.0.4-1.el7.x86_64 38/38
Verifying : fping-3.10-1.el7.x86_64 1/38
Verifying : libjpeg-turbo-1.2.90-5.el7.x86_64 2/38
Verifying : zabbix-web-3.0.4-1.el7.noarch 3/38
Verifying : php-mysql-5.4.16-36.1.el7_2.1.x86_64 4/38
Verifying : zabbix-server-mysql-3.0.4-1.el7.x86_64 5/38
Verifying : 2:libpng-1.5.13-7.el7_2.x86_64 6/38
Verifying : fontpackages-filesystem-1.44-8.el7.noarch 7/38
Verifying : php-xml-5.4.16-36.1.el7_2.1.x86_64 8/38
Verifying : php-ldap-5.4.16-36.1.el7_2.1.x86_64 9/38
Verifying : OpenIPMI-libs-2.0.19-11.el7.x86_64 10/38
Verifying : apr-1.4.8-3.el7.x86_64 11/38
Verifying : libX11-1.6.3-2.el7.x86_64 12/38
Verifying : dejavu-fonts-common-2.33-6.el7.noarch 13/38
Verifying : t1lib-5.1.2-14.el7.x86_64 14/38
Verifying : httpd-2.4.6-40.el7.centos.4.x86_64 15/38
Verifying : OpenIPMI-modalias-2.0.19-11.el7.x86_64 16/38
Verifying : mailcap-2.1.41-2.el7.noarch 17/38
Verifying : libX11-common-1.6.3-2.el7.noarch 18/38
Verifying : libtool-ltdl-2.4.2-21.el7_2.x86_64 19/38
Verifying : unixODBC-2.3.1-11.el7.x86_64 20/38
Verifying : libxslt-1.1.28-5.el7.x86_64 21/38
Verifying : php-bcmath-5.4.16-36.1.el7_2.1.x86_64 22/38
Verifying : php-mbstring-5.4.16-36.1.el7_2.1.x86_64 23/38
Verifying : php-gd-5.4.16-36.1.el7_2.1.x86_64 24/38
Verifying : dejavu-sans-fonts-2.33-6.el7.noarch 25/38
Verifying : php-pdo-5.4.16-36.1.el7_2.1.x86_64 26/38
Verifying : libXpm-3.5.11-3.el7.x86_64 27/38
Verifying : libXau-1.0.8-2.1.el7.x86_64 28/38
Verifying : httpd-tools-2.4.6-40.el7.centos.4.x86_64 29/38
Verifying : iksemel-1.4-2.el7.centos.x86_64 30/38
Verifying : zabbix-web-mysql-3.0.4-1.el7.noarch 31/38
Verifying : php-cli-5.4.16-36.1.el7_2.1.x86_64 32/38
Verifying : libzip-0.10.1-8.el7.x86_64 33/38
Verifying : php-5.4.16-36.1.el7_2.1.x86_64 34/38
Verifying : 1:net-snmp-libs-5.7.2-24.el7_2.1.x86_64 35/38
Verifying : php-common-5.4.16-36.1.el7_2.1.x86_64 36/38
Verifying : apr-util-1.5.2-6.el7.x86_64 37/38
Verifying : libxcb-1.11-4.el7.x86_64 38/38
Installed:
Dependency Installed:
Complete!
[root@acsmonitoring ~]# cd /usr/share/doc/zabbix-server-mysql-3.0.0
-bash: cd: /usr/share/doc/zabbix-server-mysql-3.0.0: No such file or directory
[root@acsmonitoring doc]# cd zabbix-
zabbix-release-3.0/ zabbix-web-3.0.4/
zabbix-server-mysql-3.0.4/
[root@acsmonitoring doc]# cd zabbix-server-mysql-3.0.4/
[root@acsmonitoring zabbix-server-mysql-3.0.4]# ls
AUTHORS ChangeLog COPYING create.sql.gz NEWS README
[root@acsmonitoring zabbix-server-mysql-3.0.4]# zcat create.sql.gz | mysql -uroot zabbix
-bash: mysql: command not found
[root@acsmonitoring doc]# service mysqld start
Redirecting to /bin/systemctl start mysqld.service
Failed to start mysqld.service: Unit mysqld.service failed to load: No such file or directory.
[root@acsmonitoring doc]# rpm -qa | grep -i mysql
[root@acsmonitoring doc]# sudo service mysqld start
base | 3.6 kB 00:00
zabbix 66/66
Installing:
Transaction Summary
Is this ok [y/N]: y
Running transaction
Installed:
Complete!
