zabbix creates ticket instead of problem
  • Flopez
    • Jun 2020
    Hello.
    I have configured zabbix 6.4 to send alerts to glpi 10.0.9, the configuration is correct but the problem I have is that
    It creates a problem for me instead of a ticket.
    What needs to be done to create tickets.
    creation is through API and a half
    thank you​
    Even the first line in installation guide says
    In GLPi
    1. Create or use existing user in GLPi with permission to create problems and followups.
    So, as long as I see it, this integration has been developed to create problems. If you need some other kind of entries, you probably need to change the integration
    https://git.zabbix.com/projects/ZBX/...72,293-294,299
    it even uses specific "Problem" API call, for opening, updating (followup) and resolve...
    • Flopez
      • Jun 2020
      Hello.
      I already have it solved, apparently I had added a means that the script only created problems.
      This script that you attach opens tickets with problems.
      This one I give you creates tickets,
      thank you​
