Problem sending notification (but when i test it works)
  • userno
    • Sep 2023
    • 19
    I'm trying to send notifications of any triggers that happens, I configured the telegram with a bot and MS Teams with the application of zabbix, when I make the test a message appears in teams and telegram but when a trigger is shot it doesn't appears.
    I have two users, one for telegram and another for teams, they have admin role and they are in the Zabbix administrators group.
    In configuration > actions > trigger actions I have the "Report problems to Zabbix administratos" with all the triggers,
    The users in the media have enabled all severitys.
    ¿What type of problem can be?
    Thanks ​
  • vijayk
    • May 2023
    • 305
    Have you check in Action Log in Report tab. Do it showing the Information as Sent?
    • userno
      userno commented
      I deleted the server so i will check when the new server will be configured
    Do your users have permissions to see those hosts/problems in Zabbix. If those are regular Admin accounts, they will only see problems in their assigned hostgroups. Zabbix Administrators group does not necessarily see every problem.
    • userno
      userno commented
      That's can be the problem but i tried with super administrator role too.
  • userno
    • Sep 2023
    • 19
    Solved, the problem was that i don't enable the trigger actions to send the notification.
