SNMP "Timeout while Connecting..."
  • mighty_oak
    • Jul 2016
    Hello.
    In my host screen, on some hosts the SNMP status frequently turns red saying
    "Timeout while Connecting to "IP":"PORT"".
    The thing is, an "snmpget" command always works and has no timeout, even when Zabbix says "Timeout... "
    Even hosts which are literally next to the zabbix server are getting this timeout frequently. Item values are stored correctly.
    What I tried so far: -unchecked "bulk request" = no improvement it's even worse, poller process popps out da roof
    looked up Server log:- revealed problems
    SNMP agent item "x1" on host "1" failed: first network error,wait for 15 sec.
    enabling SNMP agent checks on host "2": host became available
    SNMP agent item "x3" on host "3" failed: first network error,wait for 15sec.
    resuming Zabbix agent checks on host "4" and so on....
    every host is resuming/or availible again after some time...
    I did something wrong. But what?
    Could somebody push me to solution please?
  • registration_is_lame
    • Nov 2007
    • 148
    What's the timeout in zabbix server config? Default is 3 i think. Too low. Try 30 seconds
    • mighty_oak
      • Jul 2016
      SNMP COMMUNITY was wrong in item prototype
      I've found the issue.
      There was a template with item prototypes, which were set to "SNMP community = public". Since I only use custom communities, this was wrong.
      The change to {$SNMP_COMMUNITY_READ} Makro, as SNMP community value, was purposeful.
      Thanks.
