How should I set up odbc monitor item via zabbix proxy?
  • trinet
    • Sep 2021
    Env:
    CentOS 7.9
    SELinux: Disabled
    zabbix-server-4.0.24
    zabbix-proxy-4.0.24
    I setup oracle client on zabbix proxy like bellow.
    yum -y install oracle-instantclient19.11-basic-19.11.0.0.0-1.x86_64.rpm
    yum -y install oracle-instantclient19.10-odbc-19.10.0.0.0-1.x86_64.rpm
    yum -y install oracle-instantclient19.10-sqlplus-19.10.0.0.0-1.x86_64.rpm
    yum -y install unixODBC
    mkdir -p /usr/lib/oracle/19.11/client64/lib/network/admin
    cat <<_ORA_ > /usr/lib/oracle/19.11/client64/lib/network/admin/tnsnames.ora
    db01 =
    (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = xx.xx.xx.xx)(PORT = 1521))
    (CONNECT_DATA = (SERVER = DEDICATED)(SERVICE_NAME = db01)
    ​_ORA_
    cat <<_INI_ > /etc/odbcinst.ini
    [Oracle]
    Description = ODBC for Oracle
    Driver = /usr/lib/oracle/19.11/client64/lib/libsqora.so.19.1
    _INI_
    su -s /bin/sh - zabbix -c "odbcinst -j"
    unixODBC 2.3.1
    DRIVERS............: /etc/odbcinst.ini
    SYSTEM DATA SOURCES: /etc/odbc.ini
    FILE DATA SOURCES..: /etc/ODBCDataSources
    USER DATA SOURCES..: /var/lib/zabbix/.odbc.ini
    SQLULEN Size.......: 8
    SQLLEN Size........: 8
    SQLSETPOSIROW Size.: 8
    mkdir /var/lib/zabbix
    cat <<_ODBC_ > /var/lib/zabbix/.odbc.ini
    [DSNdb01]
    Driver = Oracle
    ServerName = 10.20.46.62/db01
    _ODBC_
    su -s /bin/sh - zabbix -c "isql -v DSNtmdb01 ZABBIX zYoRp4hR05DUc"
    | Connected! |
    | sql-statement |
    | help [tablename] |
    | quit |
    SQL> quit
    odbc settings are OK here.
    Next I setup zabbix.
    cat <<_ENV_ >> /etc/sysconfig/zabbix-proxy
    TNS_ADMIN=/usr/lib/oracle/19.11/client64/lib/network/admin
    LD_LIBRARY_PATH=/usr/lib/oracle/19.11/client64/lib
    _ENV_
    systemctl restart zabbix-proxy
    ​Create bellow items on the zabbix-server and zabbix proxy
    Type: Database monitor
    Key: db.odbc.select[watch-racle-alive,DSNdb01]
    User: xxxxxxxx
    Password: xxxxxxxx
    SQL query : SELECT TO_CHAR( SYSDATE, 'YYYY/MM/DD HH24:MI:SS' ) FROM dual;
    Type of information: Text
    Update interval: 60s
    But both item can not connect to the DB
    Item Status : Not supported
    Info: Cannot connect to ODBC DSN: [SQL_ERROR]:[HY000][12170][[unixODBC][Oracle][ODBC][Ora]ORA-12170: TNS:Connect timeout occurred
    There are some question
    1. is odbc setting need for zabbix-server?
    2. Where should I create odbc monitring item? zabbix server or zabbix proxy?
    Any help would be appreciated.
