Supported macro's do not work?
  • machinelearningdingetjes
    • Oct 2023
    • 10
    Hey,
    I've been trying to get a more descriptive name for my triggers but some of the supported macro's don't work, can anyone tell me why or help me with this?
    For instance, I have the following trigger name: {ITEM.NAME} - anomaly gedecteerd in de laatste 15 uur - {TRIGGER.EXPRESSION.EXPLAIN} - {ITEM.LASTVALUE1}​
    When the trigger is activated, I see the following output:
    Click image for larger version  Name:	image.png Views:	0 Size:	3.6 KB ID:	472893
    Can anyone tell me why some supported macro's do work and other don't?
    Greetings,
    machinelearningdingetjes​
    • 5008
    {ITEM.NAME} → Trigger-based notifications and commands
    → Problem update notifications and commands
    → Internal notifications
    → Manual event action scripts
    → Description of item value widget
    ​It does not say. "→ Trigger names, operational data and descriptions" as with some other built-ins...
      machinelearningdingetjes commented
      It also doesn't say that at {TRIGGER.EXPRESSION.EXPLAIN}
      {TRIGGER.EXPRESSION.EXPLAIN} → Trigger-based notifications and commands
      → Event name
    • 5008
    But it says "Event name"..
