log monitoring item(active zabbix agent) is created but it is not fetching the item and zabbix symbol is also grey.
key :- log[/var/log/zabbix/zabbix_server.log]*
As per the documents for acitve agent two things are required
1) Agent hostname must match the GUI hostname.
2) Server Active entry must be there in zabbix_agent.conf
Both conditions are fulfilled in our case still its not working.
uncommented elements in zabbix_agentd.conf
1) Server=127.0.0.1
2) ListenPort=10050
3) ListenIP=127.0.0.1
4) StartAgents=5
5) ServerActive=127.0.0.1:10050
6) Hostname=NEC_zabbix
7)User=zabbix
Thanks for your support in advance
1) Server=127.0.0.1
2) ListenPort=10050
4) StartAgents=5
7)User=zabbix
