Upgrading 6.4.7 to 6.4.8
  • phil_MTL
    • Jan 2024
    wtdrisco​, where you able to update your server?
    Similar issue but with zabbix-proxy-pgsql installed on Debian 12.
    Looking with
    apt search zabbix-[/CODE]apt search zabbix-
    zabbix-agent/now 1:6.4.9-1+debian9 amd64 [installed,local][/B][/COLOR]
    Zabbix network monitoring solution - agent
    zabbix-agent2/now 1:6.4.9-1+debian12 amd64 [installed,local]
    zabbix-apache-conf/now 1:6.4.7-1+debian12 all [installed,local]
    Zabbix network monitoring solution - apache configuration for front-end
    zabbix-frontend-php/now 1:6.4.7-1+debian12 all [installed,local]
    Zabbix network monitoring solution - PHP front-end
    zabbix-java-gateway/stable 1:6.0.14+dfsg-1 all
    network monitoring solution - Java gateway
    zabbix-proxy-mysql/stable 1:6.0.14+dfsg-1+b1 amd64
    network monitoring solution - proxy (using MySQL)
    zabbix-proxy-pgsql/stable 1:6.0.14+dfsg-1+b1 amd64
    network monitoring solution - proxy (using PostgreSQL)
    zabbix-proxy-sqlite3/stable 1:6.0.14+dfsg-1+b1 amd64
    network monitoring solution - proxy (using SQLite3)
    zabbix-server-mysql/stable 1:6.0.14+dfsg-1+b1 amd64
    network monitoring solution - server (using MySQL)
    ]zabbix-server-pgsql/now 1:6.4.7-1+debian12 amd64 [installed,local]
    Zabbix network monitoring solution - server (PostgreSQL)
    I had to update using the Zabbix repo:
    NOTE --> added a space between 6.4.9-1 and %2Bdebian12_amd64
    sudo systemctl stop zabbix-server
    sudo systemctl stop zabbix-agent2
    wget https://repo.zabbix.com/zabbix/6.4/d...an12_amd64.deb
    dpkg -i zabbix-server-pgsql_6.4.9-1+debian12_amd64.deb
    apt update
    sudo systemctl start zabbix-server
    sudo systemctl start zabbix-agent2
    apt update
    zabbix-server-pgsql/now 1:6.4.9-1+debian12 amd64 [installed,local]
