One alert for several events in a period
  • arr1val
    • Nov 2023
    Greetings.
    I use a trigger to monitor SUDO usage.
    find(/monitor sudo/log[/var/log/auth.log,sudo],,"like","sudo: gitlab-runner")=1
    During auto-deploy, about 40+ messages are generated. Is it possible to configure sending one alert message when a trigger is fired instead of 40? May be there is a condition: events by trigger in a period of time, for example a minute?
    Zabbix 6.4.5
    • 5008
    You can add additional condition to your expression ... "and nodata(/monitor sudo/log[/var/log/auth.log,sudo],1m)=0"
    then trigger will react only, if there is no incoming data for at least a minute...
    • arr1val
      arr1val commented
      Thank you! I will try it.
  • arr1val
    • Nov 2023
    Didnt help, zabbix continue to send alert messages for each event.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Consider voting for https://support.zabbix.com/browse/ZBXNEXT-39
