Help me Install zabbix agent offline on linux, ubuntu,......... T_T
  • thuantq
    • Oct 2023
    Dear support friends
    I am using zabbix server version 6.4. Currently, I have installed zabbix agent offline for windows.
    I would like to ask for your support and instructions to help me install zabbix agent offline for linux and ubuntu or other operating systems.
    I searched for information online and downloaded the installation package to install offline. After installing, the zabbix server said it was not supported.
    In case I install online, Linux: Get filesystems is supported.
    I hope the technicians will spare some time to help me.
    Thank you for reading the article​.
  • thuantq
    • Oct 2023
    Sorry, can anyone help me find the reason for the "get file system" item error?
    Currently, I have installed offline zabbix agent for ubuntu 18.0 LTS but it does not support the "get file system" item when connecting to zabbix server 6.4​
    • Vermizz
      • Oct 2022
      • 33
      Do other items work properly on this host?
      Send a screenshot of the configuration of this item "Get filesystems"​.
      From zabbix server run test command:
      zabbix_get -s [IPUbuntuTest] -p 10050 -k vfs.fs.get
      • Vermizz
        Vermizz commented
        You need to remove [] from the command
        zabbix_get -s 172.86.1.139 -p 10050 -k vfs.fs.get
      • thuantq
        thuantq commented
        Hi Vermizz,
        i am send log
        root@ubuntu01:~# zabbix_get -s 172.86.1.139 -p 10050 -k vfs.fs.get
        ZBX_NOTSUPPORTED: Unsupported item key.
      • thuantq
        thuantq commented
        Hello Vermizz,
        My host is currently using ubuntu18.0 and I have installed offline version zabbix-agent_2.0.9-1_amd64.deb.
        This offline zabbix agent session was just installed for my ubuntu18.0. I tried the offline version of zabbix_agent but it says it doesn't support ubuntu 18
        The point to note here is that if I install zabbix_agent online for Ubuntu 18.0, the item "vfs.fs.get" is supported.
    • Vermizz
      • Oct 2022
      • 33
      Zabbix agent 2.0.9 is very old.
      How you install this package?
      btw if the server is offline can you download the package locally and send it to it using winscp?
      Can you do this:
      1. Download the package from: ​https://repo.zabbix.com/zabbix/6.4/u...8.04_amd64.deb
      If you need other version check: https://repo.zabbix.com/zabbix/6.4/u...main/z/zabbix/
      2. Install package:sudo apt install /path/to/package/name.deb
      • thuantq
        thuantq commented
        Hello Vermizz,
        Very thank you. My host dowload and install zabbix-agent_6.4.6-1+ubuntu18.04_amd64.deb --> fix item not support
