Creating a discovery rule for Nginx
  • archer1
    • Nov 2023
    Hi!
    I have a server running nginx, and there are a large number of configurations for different web resources, each configuration has its own redirection rules and upstreams.
    From time to time errors such as (three examples for different domains) appear in different logs (each domain has its own log).
    2023/11/17 16:00:27 [error] 90304#90304: *16977866956 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 10.0.0.1, server: my1.site.com, request: "GET /papi/1.0/40-a46a-bdd7e4749 HTTP/1.1", upstream: "http://10.0.0.2:30415/60-d74f", host: "my1.site.com"
    2023/11/17 16:00:27 [error] 90305#90305: *16977868169 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 10.0.58.1, server: my2.site.com, request: "PUT /papi/1.0/b9ad-4c28 HTTP/1.1", upstream: "http://10.0.0.3:30415/papi/1.0/c28-b913-02aebafeea", host: "my2.site.com"
    2023/11/17 16:00:28 [error] 90301#90301: *16977870167 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 10.0.0.8, server: my3.site.com, request: "GET /papi/1.0/d-6329-4c78-ba08 HTTP/1.1", upstream: "http://10.0.0.92:30415/912d-6329-", host: "my3.site.com"​
    I need to receive information from Zabbix about whether there are errors in the logs, as an example, I’m trying to count the number of matches in the last minute
    awk '($0 >= from)' from="$(LC_ALL=C date +"%Y/%m/%d %H:%M" -d -1minute)" /var/log/nginx/* | grep "Connection timed out" | wc -l​
    I send the number of errors found to Zabbix and if the number of errors is greater than my trigger threshold, the trigger is triggered. Graph for example
    But I have a lot of different domains that are serviced on Nginx, and I also have several such environments with other domains. Because of this, the resulting number of errors is not particularly informative, since there is no understanding for which specific domain errors occur
    Perhaps there is an option, based on the log that I provided, to receive information not only about the number of errors over a certain period of time, but also to compare them with the domain and transfer all this information to Zabbix.
    Ideally, use Discovery Rules in a zabix template for this. That is, based on the data received about the domain and the number of errors found for this domain, automatically create a new item with the name of the domain and a trigger for it, and so that in the future all errors found are compared with this domain, if the item for it already exists in Zabbix, and not there is a need (for example, a new configuration has been added to Nginx for a new domain), create a new item again
    I still can’t figure out how to implement it correctly. Maybe someone has a simple solution?
  • Brambo
    • Jul 2023
    • 250
    I can't help you with the specific code as I'm not that good in creating it myself
    However you need to start to create an item which gathers the directory name of the main folder. As those names are the items you want to create.
    So your items get's the data and if needed do pre-processing to create an json output from it.
    The go to the discovery section of that template, depended item on your main item > match the LLD macros to the json output of the main item.
    From here you need to figgerout how/which data you want to have in the item which you can do with json path in the pre-processing of you Item prototype.
    Hope this sets you on the right path.
    • Semiadmin
      • Oct 2014
      • 1626
      vfs.dir.get[/var/log/nginx,".*\.log$",,file,,0]
