Help with ICMP monitor (6.4)
  • rebidebi
    • May 2023
    • 11
    I know it might sound silly but im not sure what im missing..
    im trying to configure a new host only with icmp ping to get alerts when it gets down, but when adding the host, i have to choose "agent", which means i have to choose a port.
    in this case, the host will always be greyed out.
    how can i set up icmp monitoring correctly?
    added pic for refrence
    Click image for larger version  Name:	image.png Views:	0 Size:	31.4 KB ID:	474632​
  • solution
    • Jun 2020
    • 272
    icmping uses the IP defined in Agent, the port is not used but needs to be present, so leave it as it is.
    in this case, the host will always be grayed out.
    icon in the "availability" column?​
    check the requirements
    Wellington
