Monitoring PWWN Cisco MDS
  • Rodolfo Rojas
    • Jun 2023
    Hello all,
    I’m trying to monitoring pwwn Cisco MDS devices, I need to monitoring maybe with an item prototype each port and validate if that port has an active login.
    Something like command line as
    HTML Code:
    show flogi database interface xxx
    but with SNMP
    ​ and for active logins might return INTERFACE, VSAN, FCID, PORT NAME,NODE NAME otherwise have 0 lines, this is what I actually need, if I have 0 lines fire the trigger.
    So far I’m using 1.3.6.1.4.1.1.9.9.91.1.1 but it brings too much information and I do not know what I need or even if I’m using the correct OID
    Has anyone implemented any similar monitoring for these devices?
