Zabbix traps via bash script don't work
  • Paul_11
    • Dec 2023
    Hi!
    I've got Zabbix 6.0.4 on CentOs stream release 8.
    I've configured snmp trap receiver exactly as in manual:
    I use /var/lib/zabbix/snmptraps/snmptraps.log file like a ZABBIX_TRAPS_FILE in bash script and SNMPTrapperFile in zabbix_server.conf
    I can see snmp traps coming from network devices in tcpdump.
    But traps from network interface does not appear in the file snmptraps.log, the file is not created.
    When I use the command like a (snmptrap -v 2c -c public 10.128.10.14 '' .1.3.6.1.6.3.1.1.5.3 .1.3.6.1.6.3.1.1.5.3 s "ens192") on server itself the snmptraps.log file is created and trap enters the file.
    Please help with this problem, what's wrong with my config.​
  • Paul_11
    • Dec 2023
    Hi!
    I think script is fine.
    But I can't understand this problem:
    Cannot bind for clientaddr: Address already in use
    couldn't open udp:162 -- errno 98 ("Address already in use")​
    [root@monitor]# sudo snmptrapd -f -Lo -c /etc/snmp/snmptrapd.conf
    [root@monitor]# cat /etc/services|grep 162
    snmptrap 162/tcp # SNMPTRAP
    snmptrap 162/udp snmp-trap # Traps for SNMP
    [root@monitor]# sudo netstat -lnp| grep 162
    udp 0 0 0.0.0.0:162 0.0.0.0:* 1036785/snmptrapd
    [root@monitor]# ps -ef | grep snmptrapd
    root 1036785 1 0 15:59 ? 00:00:00 /usr/sbin/snmptrapd -Lsd -f
    root 1037076 72730 0 16:00 pts/0 00:00:00 grep --color=auto snmptrapd​
    ​As I can see only snmptrapd uses port 162 and I can't find out another application using this port.
    How can I resolve this issue?
    • ISiroshtan
      • Nov 2019
      • 324
      If snmptrapd already running when you execute
      means you try to invoke another instance of it, which can not use the same port that already running instance is using. Hence you get an error. Stop running instance then invoke your command from shell.
      Could you show /etc/snmp/snmptrapd.conf content and the tcp dump of the trap that is not processed to log?
      • Paul_11
        • Dec 2023
        Ok, but how can I stop instance correctly?
        If I use kill command I've got the same error:
        [root@monitor]# systemctl restart zabbix-server.service
        [root@monitor]# systemctl restart snmptrapd.service
        root 1054128 1 0 17:21 ? 00:00:00 /usr/sbin/snmptrapd -Lsd -f
        root 1054145 72730 0 17:21 pts/0 00:00:00 grep --color=auto snmptrapd
        [root@monitor]# kill 1054128
        [root@monitor]#​
        • ISiroshtan
          • Nov 2019
          • 324
          I don't see any obvious issue with config file and trap from dump. If you say your locally sent trap did get logged, this one should too.
          You can just stop snmptrapd as
          systemctl stop snmptrapd
          then verify that port is no longer listened by anything
          Then you can try to execute your command to get log in console about traps
          • Paul_11
            • Dec 2023
            Unfortunately the same error:
            [root@monitor]# systemctl stop snmptrapd
            [root@monitor]#​
            Now trap from cli also don't work (no file is created with test trap)
            • Paul_11
              • Dec 2023
              In my last post - I used bad trap format from cli.
              Now I can see that trap from cli works fine.
              How can I debug (maybe enable some logs/debugs) to check traps from network interface?
                • 5002
                SO, traps arrive as they are visible in tcpdump, but they only reach traplog if it is sent from localhost?
                Have you checked selinux errors? Do you have somekind of local firewall enabled?
