Best Practice to Upgrade Zabbix Agent
  • BalaC
    • Sep 2021
    • 22
    I'm running Zabbix server 6.0 LTS version and all hosts are with Zabbix-agent and I want to upgrade the agent to zabbix-agent2 now.
    What will be the best practice to do this?
    1) I will be able to convert the old data to the agent zabbix-agent2?
    2) If no, how to delete the zabbix-agent data which anyways will not be useful for agent2.
    What do you mean with "old data" ? In general, uninstall classic agent and install agent2. Most of configuration file is even the same, so transfer needed things to agent2 config (Server, ServerActive , poller counts etc). Start it up and enjoy..
    • BalaC
      • Sep 2021
      • 22
      Thanks for the update, I mean also need to move the new Template Linux OS, then I will loose historic data. So do I need to remove the history data from database? or it is possible re-import it? If so any guide on this how to remove it.
