Unable to retrieve body information from URL with zabbix againt
  • ISiroshtan
    • Nov 2019
    • 324
    #16
    You can add
    -m 10
    to curl command to add 10 seconds timeout, but essentially communication is not happening and you would need to check the routing/firewalls that might be preventing communication from Zabbix to your web server.
    Edit: As you added info that ping works, means routing is fine. So that leaves firewalls either on web server or in between.
    • SpeedyGonzalesNL
      • Oct 2023
      • 23
      #17
      Let me check with the firewall guys, will come back later on this matter.
      Thanks for the information so far
