How to configure monitoring on LDAP?
  • mafonso
    • Dec 2023
    Hello all,
    I would like to configure LDAP monitoring in zabbix 6.4 under.
    My zabbix serer is in Linux RHEL.
    Do you know any good tutorial on the subject?
    Or can you provide steps ?
    I know that I can go to integrations in zabbix and download a template but not sure on the steps.
    Thank you !
    Best regards
  • atenagoras
    • Dec 2023
    Hi mafonso.
    Would you like to login in Zabbix from LDAP, or do you want monitor a LDAP server?
