Count Of Trigger
  • marcooob
    • Dec 2023
    Count Of Trigger
    Hi everyone, sorry if this topic has already been discussed.
    I would like to understand if it is possible to make a trigger count.
    I have a trigger that tells me when a printer has run out of ink, I would like to associate a new one that counts how many times that trigger is triggered so I can have statistics for the last 7 days.​
    thank you very much​
  • Brambo
    • Jul 2023
    • 256
    https://www.zabbix.com/documentation...fic-parameters
    Use the sum feature and put in the time period you want to validate If I was you i would try to make an item which is 0 when inkt is OK and 1 when its out. Then this sum feature works fine
    Well that calculates the values, if you really want to count the amount of times the trigger has triggered then you maybe have to find a better solution to keep track of the run out messages.
    In theory you could create a depending item but to what reason... and how is something different
    • marcooob
      • Dec 2023
      thank you very much Brambo! to do the sum, can't I enter a host group instead of just 1 host?Click image for larger version
