Zabbix Proxy Configuration
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    Is there a document that describes the proxy options? I am trying to setup a remote Zabbix proxy, so all my remote devices talk to the proxy. I am looking to see what each option means and whether I need to use them. For example the proxy has a server port and listen port option. I plan on configuring for active and passive checks. Which is which?
    Thanks,
    Steve
  • Answer selected by stevefxp at 05-01-2024, 23:05.
    ISiroshtan
    • Nov 2019
    • 324
    Did you try to verify tcp communication flow? Running from proxy something like:
    telnet zabbix_server_ip 10051
    or
    nc -v zabbix_server_ip 10051
    If it fails then failure is on network level, with possibly firewalls, routing or some other permissions.
    • ISiroshtan
      • Nov 2019
      • 324
      • stevefxp
        • Aug 2020
        • 168
        Thank you very much. I did not know there was comprehensive documentation...
        A couple more questions when it comes to a Zabbix proxy:
        1) What is the difference between active and passive communications, when it relates to the proxy? Is it the same as an agent talking to the main Zabbix server?
        2) I can get the proxy to talk to the main Zabbix server via passive communications, but it will not via active. I get the following error on the proxy side: Unable to connect to [192.168.2.98]:10051 [cannot connect to [[192.168.2.98]:10051]: [4] Interrupted system call]
        3) I thought passive port was 10050 and active port was 10051. The attached screenshot is right from the proxy configuration documentation and it shows that the default passive proxy port is 10051. Is this a typo?
Name:	Screenshot 2024-01-04 125539.png
        • ISiroshtan
          • Nov 2019
          • 324
          I find this picture super helpful whenever I forget some details about how communication between Zabbix components happen (whihc happens more often then I'd like to admit).I think it should cover core of all your questions. But if you still have doubts - please do ask.
          • stevefxp
            • Aug 2020
            • 168
            Did you forget the picture??
          • stevefxp
            • Aug 2020
            • 168
            Ok so to confirm:
            1) Agent communication can be 10050 or 10051
            2) Proxy communication is 10051, regardless or passive or active
            If the above is true then I do not understand why my proxy cannot speak to my main Zabbix server over port 10051 for active communications, when passive communications works. This tells me its something else from a config perspective.
            • ISiroshtan
              • Nov 2019
              • 324
              or
              • stevefxp
                • Aug 2020
                • 168
                Yes it looks like I have a network issue on one side. Thanks for pointing me in the right direction.
                • irontmp
                  • Sep 2023
                  • 99
                  Server (Server/ServerPort) = active mode, proxy connects out to the Zabbix server.
                  ListenPort = passive mode, proxy listens for incoming connections from the server. If you want both active and passive checks, this is exactly what you need to configure — set Server to your Zabbix server's address and leave ListenPort at its default (10051).
                  Full parameter reference: Zabbix documentation, "Configuration files", zabbix_proxy.conf
