Managed to break widget.view.php - Please help!
  • Alistair.Davies
    • Dec 2023
    Hi Guys,
    Could someone point me in the right direction please, I was messing around with the ITEM VALUE widget and have managed to break it.
    The code I was editing is under /usr/share/zabbix/widgets/item/views/widget.view.php
    My question is there a way to repair Zabbix front-end just to fix the widget or is there a repo where I can copy the original php code or does anyone have the original code, I have attached the piece of broken code along with a screenshot of the dashboard all the data is still saved in the widget I just cannot view it in the dashboard, the version of Zabbix is 6.4.10 and is running on a Azure container instance of Red Hat Linux Enterprise Version 8.6
    Thanks in advance
  • Hamardaban
    • May 2019
    • 2714
    Look at https://git.zabbix.com/projects/ZBX/...idget.view.php
      Next time create a backup first..
      • Alistair.Davies
        • Dec 2023
        cyber yes a very silly mistake I still haven't managed to fix it would renaming the PHP file help?
          Hamardaban gave you the link to "original".. copy all the content to your file, it should be ok after that. Then make a copy of the original and try your changes again... You can always copy back the working one.
          EDIT: ok .. maybe you need some other file.. not exactly sure which one you edited... But you should be able to find it from zabbix git anyway...
          • Alistair.Davies
            • Dec 2023
            Thank you guys I have managed to find the right php code and copying it over the old broken code, all is working again
