Alert from dashboard isn't clearing though zabbix_get/latest data works fine
  • zabbixfk
    • Jun 2013
    • 256
    Hello All,
    I have a weird situation in case of one of my added windows server w.r.to. agent not reachable trigger. I see that this trigger is populated under my dashboard under host status. Where as, i have agent up and running on that machine, latest data looks fine, and zabbix_get works fine too.
    But below trigger is not disappearing from dashboard/host status
    Trigger Window has below details:
    Severity - Warning
    Status - PROBLEM
    Info -
    Last change - 04 Aug 2016 13:42:58
    Age - 1m 24d 1h
    Acknowledged - Acknowledged
    Host	- ABC-DEF-DC1
    Name - Zabbix agent on ABC-DEF-DC1 - 192.168.1.1 is unreachable for 5 minutes
    Comments - Add
    Corresponding Event window for that host has below details
    Time	- 04 Aug 2016 13:42:58
    Description - Zabbix agent on ABC-DEF-DC1 - 192.168.1.1 is unreachable for 5 minutes
    Status - PROBLEM
    Severity - Warning
    Duration - 1m 24d 1h
    Ack - Yes (1)
    Actions - 4	1
    Point to be noted is, when i disable that host from monitoring this line disappeares under host status on dashboard, and when enabled it just comes back. When the latest data is up , zabbix_get works fine that means agent is reachable, isn't this trigger should have disappeared long back? (just a question)
    Can somebody help me to understand why this PROBLEM has not cleared, or any pointers on making it disappear would be of great help
  • tomga
    • Sep 2016
    Same Problem for me too.
    Problems occur after Update 3.0 to 3.2.
