How do I change a default value
  • hcaeb2000
    • Feb 2024
    Hello, I would like to raise
    {$CPU.PRIV.CRIT.MAX}
    from the default 30 value to something higher to avoid unnecessary notifications. Is there a way to change that default value? How would I go about doing that?
    Thanks,
    Rich
  • azyla
    • Feb 2024
    • 20
    Based on the build of the macro I can tell this one is user-defined macro and it should be relatively easy to amend. First of all try to figure out on what level is that macro configured: global, template or host.
    • for global macros visit Administration -> Macros
    • for host and template level macros, open host or template properties and look for the Macros tab
    From there just change it's value in Value field to whatever suits your needs.
    If you need any further information about this particular topic, this site should be useful: https://www.zabbix.com/documentation...os/user_macros
    Hope it resolves your issue.
    Regards,
    Arkadiusz​
    • yau
      • Dec 2023
      • 16
      2 cents:
      1. for few deviatons: Open one Host -> click on Tab Macros -> Click on Tab Inherited and Host Macros
      2. for larger groups of hosts with deviating macro values: create a new Template for each group and inherit the Macros at the same place as in 1.
      • hcaeb2000
        • Feb 2024
        Thanks for the responses everyone, with your help I was able to figure it out.
        Rich
