Zabbix network traffic
  • xergiopd
    • May 2016
    Hi @all,
    does anyone know if it is possible to create a rule to filter incoming traffic from different networks? For example, track the incoming traffic on the server X from the 192.168.1.0/24 network?
    Thanks all.
  • Colttt
    • Mar 2009
    • 878
    so far as i know it is not possible yet, but you can create a feature request for this
    Debian-User
    Sorry for my bad english
    • bbrendon
      • Sep 2005
      • 873
      yes. with iptables or some open source tool. I know for sure one of the open source tools will count traffic for network traffic that you choose using the linux kernel and you can just query the kernel using a cli command and put it into zabbix.
      It's been many years since i've done this and I don't recall the details but its possible.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • burn1024
        • Jun 2012
        • 52
        I don't think it was a question about counting traffic.
        Limiting is dead simple with iptables, though.
