Problem with allowing external connections on Zabbix Server
  • LucieKitsune
    • Feb 2024
    I just downloaded and set up zabbix frontend on a Ubuntu 22.04 VM.
    My problem now is that I am not able to add external servers to monitor or connect to the frontend using the public IP adress (http://PublicIP/zabbix)
    I can only access it internally with the local IP (192.168. etc etc)
    Do I have to open certain port, mess up with the firewall or router?
    Note that the Zabbix Server is hosted under a VM on my windows 11 computer at my house, I don't know exactly where to go as I usually used zabbix at work which was hosted inside a Exsi Vmware under a external server host (OVH).
    Thank you for your help.
  • solution
    • Jun 2020
    • 271
    What you are looking for is called "port forward"
    Read:
    https://www.softwaretestinghelp.com/...rts-on-router/
    Search:
    Wellington
