How to calculate running time of computer
  • tommg83
    • Mar 2024
    Hello all,
    That is my first post. I would like to ask if possible is to calculate running time of computer. I need to carry out the report every month how long the computer was off and how long on. I will be aprechiate for your help.
    Best regards
    Tomasz
  • tommg83
    • Mar 2024
    I found the graph below but i can't check total uptime.
    • markfree
      • Apr 2019
      • 875
      Maybe you could create a calculated item that adds up all the max values from a month.
      However, I'm not sure which function and calculation you would need in this case.
      Have a look at the supported functions.
      You could also try a different approach.
      Combining a service monitoring with an SLA could could give you some simple reports.
