No e-mail notifications for "Disk space critically low" events
  • XceptN
    • Mar 2024
    Newbie here.. In two separate Zabbix installations (one of them is on my laptop - 6.4.12) the
    /: Disk space is critically low (used > {$VFS.FS.PUSED.MAX.CRIT:"/"}%)
    trigger generates events but I do not get "Media Type" notifications (e-mail etc.) ..
    When I examined the events, I noticed that OK events are generated instead of PROBLEM. I suspect that may be the reason that notifications (e-mail etc.) are not sent.
    E-mail notifications work otherwise (i.e. with Test).
    How can I get this working?
  • Answer selected by XceptN at 21-03-2024, 14:00.
    cyber
    • 4957
    You said "When I examined the events, I noticed ..." what do you mean by that? Went to trigger config page and noticed that there is green OK beside each of them? That does not mean they generate OK events.. it means they are in OK state right now..
    https://www.zabbix.com/documentation...hosts/triggers
    Value Trigger value is displayed:
    OK - the trigger is in the OK state
    PROBLEM - the trigger is in the Problem state
      • 4957
      OK will not be generated without it first going to PROBLEM state...
      • XceptN
        XceptN commented
        When I filter only for PROBLEM event, nothing is listed, but all OK are listed. Do you mean that the same 'event' converts from PROBLEM to OK, instead of a new OK event is generated?
      • 4957
      • XceptN
        • Mar 2024
        Thanks a lot .. I see where I went wrong.. I have been considering the "triggers" list as if it was a "log". I re-did a test on my test environment and it is all clear now.. Thanks a lot ..
