Delayed zabbix telegram notification
  • pirogue
    • Mar 2024
    Hi!
    I have a js script that sends a notification to telegram every time a client's server is down. Currently it sends a notification the very second problem occurs. The problem is, servers tend to go up and down very often, so I have a lot of garbage in our chat, stuff like "problem has been resolved in 2 minutes" I would like zabbix to only to send a notification if a problem persists for more that an hour.
    I tried to modify my script, but to no avail.
    I know that this can be done with triggers, but that way our graphs are going to have a funny look.
    var Telegram = {
    token: null,
    to: null,
    message: null,
    proxy: null,
    parse_mode: null,
    escapeMarkup: function (str, mode) {
    switch (mode) {
    case 'markdown':
    return str.replace(/([_*\[`])/g, '\\$&');
    case 'markdownv2':
    return str.replace(/([_*\[\]()~`>#+\-=|{}.!])/g, '\\$&');
    default:
    return str;
    sendMessage: function () {
    var params = {
    chat_id: Telegram.to,
    text: Telegram.message,
    disable_web_page_preview: true,
    disable_notification: false
    data,
    response,
    request = new CurlHttpRequest(),
    url = 'https://api.telegram.org/bot' + Telegram.token + '/sendMessage';
    if (Telegram.parse_mode !== null) {
    params['parse_mode'] = Telegram.parse_mode;
    if (Telegram.proxy) {
    request.SetProxy(Telegram.proxy);
    request.AddHeader('Content-Type: application/json');
    data = JSON.stringify(params);
    // Remove replace() function if you want to see the exposed token in the log file.
    Zabbix.Log(4, '[Telegram Webhook] URL: ' + url.replace(Telegram.token, '<TOKEN>'));
    Zabbix.Log(4, '[Telegram Webhook] params: ' + data);
    response = request.Post(url, data);
    Zabbix.Log(4, '[Telegram Webhook] HTTP code: ' + request.Status());
    try {
    response = JSON.parse(response);
    catch (error) {
    response = null;
    if (request.Status() !== 200 || typeof response.ok !== 'boolean' || response.ok !== true) {
    if (typeof response.description === 'string') {
    throw response.description;
    else {
    throw 'Unknown error. Check debug log for more information.';
    try {
    var params = JSON.parse(value);
    if (typeof params.Token === 'undefined') {
    throw 'Incorrect value is given for parameter "Token": parameter is missing';
    Telegram.token = params.Token;
    if (params.HTTPProxy) {
    Telegram.proxy = params.HTTPProxy;
    params.ParseMode = params.ParseMode.toLowerCase();
    if (['markdown', 'html', 'markdownv2'].indexOf(params.ParseMode) !== -1) {
    Telegram.parse_mode = params.ParseMode;
    Telegram.to = params.To;
    Telegram.message = params.Subject + '\n' + params.Message;
    if (['markdown', 'markdownv2'].indexOf(params.ParseMode) !== -1) {
    Telegram.message = Telegram.escapeMarkup(Telegram.message, params.ParseMode);
    Telegram.sendMessage();
    return 'OK';
    catch (error) {
    Zabbix.Log(4, '[Telegram Webhook] notification failed: ' + error);
    throw 'Sending failed: ' + error + '.';
    the script
    I am using zabbix 5.0.41
    escalation steps and their timing is the key... https://www.zabbix.com/documentation...on/escalations
    • pirogue
      • Mar 2024
      Thank you for your answer, cyber! I'll check them out today
