Zabbix apc ups by snmp, hot to trigger when power off ?
  • Murilo Ribeiro
    • Sep 2023
    • 14
    Hi!
    I'm monitoring some apc ubs using snmp with default template (https://www.zabbix.com/integrations/apc_ups_snmp)
    But i wanted to create a trigger when power off in the unity but i don't know what item can i use to put the trigger. Somebody help me, please?
    Because sometimes in this unity the energy goes off and the apc start using the battery mode and not triggered us when the power is off.
  • Answer selected by Murilo Ribeiro at 04-04-2024, 13:52.
    cyber
    So you want a trigger, when input power is cut? There seems already be one trigger about this
    {#PHASEINDEX}: Unacceptable phase {#PHASEINDEX} input voltage
    • Murilo Ribeiro
      Murilo Ribeiro commented
      Yes, that's it but my apc ups is not discovering this item, i don't know why... I'll have to discover why this item and trigger is not discovering... Do you have any idea?
  • Murilo Ribeiro
    • Sep 2023
    • 14
    Anyone can help me, please?
      • Murilo Ribeiro
      Is there any errors for discovery? Are they in some reason "not supported"? Can you do similar discovery form command line (snmpwalk answers with enough data?)? Too many unanswered questions.. But nothing I can really help with. You need to investigate locally...
      • Murilo Ribeiro
        Thanks, is kind of complicated to discover what is real reason that's not working. Thank you, Cyber!
