Item name not showing after update
  • MarcosP
    • Apr 2024
    I'm somewhat new to using Zabbix, so this might be a dumb question, but here it is:
    I recently set up a new Zabbix server running version 6.0. I then exported all my hosts and templates from my previous Zabbix instance, which was running version 4.4. The issue I'm encountering is that my item names contain "$1", and after some research, I discovered that this feature was deprecated in this version.
    However, I'm not entirely sure how to resolve this problem. I would manually change each item if possible, but I believe the items discovered by templates are read-only. Therefore, I think I can only modify item prototypes through the discovery rule, but I'm unsure what I should write to make everything work.
    What should I enter in the "Name" field to replace "$1"?
    A print from my latest data from one of my hosts:
  • Answer selected by MarcosP at 26-04-2024, 20:17.
    cyber
    Originally posted by Hamardaban
    Positional macros no longer supported
    The support for positional macros in item name ($1, $2...$9), deprecated since Zabbix 4.0, has been fully removed.
    He knows that.. question is, with what to replace it with ...
    I think {#SNMPVALUE} in this case.
    • MarcosP
      MarcosP commented
      Thats it, it works. Thanks for help
  • Hamardaban
    • May 2019
    • 2714
      • MarcosP
        MarcosP commented
    • Hamardaban
      • May 2019
      • 2714
      Oops.... I missed it....
      Yes - {#SNMPVALUE} is a good choice
