Dashboard Graph widget question
  • olegus
    • Dec 2023
    • 73
    I added a Graph widget to display housekeeper utilization, which constantly reports problems being >75%:
    On the edit screen it shows 100% utilization on Y axis.
    Once saved, on Dashboard it shows 8% utilization:
    What am I doing wrong?
  • Hamardaban
    • May 2019
    • 2714
    Show the "Data set #1" graph settings.
    • olegus
      • Dec 2023
      • 73
      Here it is:
      • Hamardaban
        • May 2019
        • 2714
        Try set “Approximation” to “all”.
        • olegus
          • Dec 2023
          • 73
          ok, Approximation=All sort of works. Now it shows this:
          And I do not really understand what does it show now.
          Red line is still under 10%, pink area is maxed out.
          And we receive alerts on housekeeper utilized >75% every hour.
          • Hamardaban
            • May 2019
            • 2714
            Red line -> avg.
            Choose a shorter display interval (1 or 2 hours)- I think you will see sharp peaks hourly. And if you calculate the average, then you get something like 10%.
            Look in the db server log - there are probably records of a slow request.
            You probably need to figure out how your housekeeping is set up and tune the base or equipment
            • olegus
              • Dec 2023
              • 73
              ok, NOW it makes sense
              Thanks, Hamardaban being patient with me... Is there best practices how to mitigate those spikes in housekeeping? Scale up VMs? We have ~1500 hosts and projected to have ~2000.
