Zabbix7.0.rc1 cannot initialize asynchronous DNS library
  • wangjun
    • Jan 2021
    Failed to start zabbix in an intranet environment.
    Zabbix Version:7.0.rc1
    Zabbix is installed on both internal and external servers and can not be started without internet access.
    zabbix server log:
    3338:20240523:141202.732 for a discovery process with 5 workers, the user limit of 1024 file descriptors is insufficient. The maximum number of concurrent checks per worker has been reduced to 122
    3370:20240523:141202.795 cannot initialize asynchronous DNS library
    3369:20240523:141202.795 cannot initialize asynchronous DNS library
    3330:20240523:141202.976 [1] thread started [preprocessing worker #1]
    3330:20240523:141202.980 [2] thread started [preprocessing worker #2]
    3330:20240523:141202.980 [3] thread started [preprocessing worker #3]
    3310:20240523:141202.991 One child process died (PID:3369,exitcode/signal:1). Exiting ...
    3317:20240523:141202.992 HA manager has been paused
    zabbix_server [3310]: Error waiting for process with PID 3369: [10] No child processes
    3317:20240523:141203.178 HA manager has been stopped
    3310:20240523:141203.199 syncing trend data...
    3310:20240523:141203.203 syncing trend data done
    3310:20240523:141203.204 Zabbix Server stopped. Zabbix 7.0.0rc1 (revision c3509cfd591).
    What's the problem? How to solve it?
  • Markku
    • Sep 2018
    • 1784
    There is an issue for this, follow that for updates: https://support.zabbix.com/browse/ZBX-24532
    Markku
    • Markku
      • Sep 2018
      • 1784
      Please go to the Zabbix support portal and search for ZBX-24532, there is an open issue for this already, follow that for updates on the issue.
      Markku (my previous post was Unapproved because it has link to the support portal, that's currently not allowed)
      • wangjun
        wangjun commented
        Thank you for your reply. Is this problem solved? I don't seem to see it,I'll keep an eye on it.
      Markku Nothing wrong with your post at the moment... link to support site is nicely visible... Either approved or it was some glitch in matrix...
      • Markku
        Markku commented
        Yeah, apparently someone carefully evaluated my post and decided that the link to Zabbix support site can be allowed in the forum after all. I think I'll try again on the "other topics" forum...
        Markku
