Customise individual disk space alert trigger limits
  • Taomyn
    • Feb 2021
    • 21
    When using the various OS templates that monitor disk space use, how can I adjust the trigger levels for each discovered disk? As I can see it, I'm running Zabbix v7, the available macros are generic across all the disks for the host, so when a server has a 500GB C: drive and a 100TB D: drive, having triggers set at 80% and 90% makes no sense for the D: drive but there is no separate macro just for the D: drive.
  • Answer selected by Taomyn at 07-06-2024, 14:19.
    cyber
    • 5002
    Docs... https://www.zabbix.com/documentation...macros_context
      • 5002
      • Taomyn
        • Feb 2021
        • 21
        Just for closure as I don't like solved threads where the actual solution never gets mentioned, simply adding this to the host macros was my solution:
        Thank-you cyber
