using agent 5 with zabbix 7
  • ddrucker
    • Feb 2019
    • 35
    Among the machines I look after are a couple of very elderly ones which are on RHEL 5, kernel 2.6.18. They are medical devices which cannot be updated. I would like to switch to Zabbix 7, but apparently it won't work with agents older than v5.
    It appears that the v6 agent won't work on kernel 2.6.18: https://support.zabbix.com/browse/ZBX-3395
    Can someone either explain how to compile a v6 agent to wor on kernel 2.6.18, or give me a better idea (which doesn't involve updating the OS, which is not going to happen)?
  • Answer selected by Markku at 11-06-2024, 06:31.
    Markku
    • Sep 2018
    • 1784
    Can you tell us more about your experiences? The compatilibity documentation states that "To be compatible with Zabbix 7.0, Zabbix agent must not be older than version 1.4 and must not be newer than 7.0."
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • ddrucker
        • Feb 2019
        • 35
        Huh. I'm so sure I read on that very page that agents could only be one major version behind, but now I can't find that text. I guess I imagined it. Thanks.
