Zabbix-proxy pod is crashing while installing on AWS EKS
  • gmarri
    • Jun 2024
    Followed below link for installing Zabbix on AWS Elastic Kubernetes Service (EKS)
    https://git.zabbix.com/projects/ZT/r...heads%2Fmaster
    However, after installation "zabbix-proxy" pod is crashing. Below is the error log.
    846:20240611:133038.628 Starting Zabbix Proxy (active) [zabbix-proxy]. Zabbix 7.2.0alpha1 (revision aab032e).
    846:20240611:133038.628 **** Enabled features ****
    846:20240611:133038.628 SNMP monitoring: YES
    846:20240611:133038.628 IPMI monitoring: YES
    846:20240611:133038.629 Web monitoring: YES
    846:20240611:133038.629 VMware monitoring: YES
    846:20240611:133038.629 ODBC: YES
    846:20240611:133038.629 SSH support: YES
    846:20240611:133038.629 IPv6 support: YES
    846:20240611:133038.629 TLS support: YES
    846:20240611:133038.629 **************************
    846:20240611:133038.629 using configuration file: /etc/zabbix/zabbix_proxy.conf
    846:20240611:133038.630 [Z3005] query failed: [0] no such table: users [select userid from users limit 1]
    846:20240611:133038.630 cannot use database "/var/lib/zabbix/db_data/zabbix-proxy.sqlite": database is not a Zabbix database
    Any ideas ?
    Thank you in advance!
    • 4996
    Why do you need same topic several times? This is duplicate of https://www.zabbix.com/forum/zabbix-...bix-on-aws-eks
