API Help - Filter value by greater, or less, than a different value
  • epau
    • Jun 2024
    I'm using the Python API and doing a history.get with itemids as a parameter and then comparing the clock value to other variables I have in my Python script to create a new dicitionary with only history within that timeframe.
    I was wondering if it were possible to do something like this through the zabbix API alone, e.g through the filter parameter?
  • Answer selected by epau at 17-06-2024, 10:45.
    cyber
    • 4993
    https://www.zabbix.com/documentation...ce/history/get
    time_from timestamp Return only values that have been received after or at the given time.
    time_till timestamp Return only values that have been received before or at the given time.
      • 4993
