Upgrade Zabbix 6.0 to 7.0 problem
  • Alrightbabyboy
    • Jun 2023
    • 48
    hello,
    I tried to upgrade my zabbix server to 6.0 LTS -> 7.0LTS.
    I followed instructions here : https://www.zabbix.com/documentation.../debian_ubuntu
    I did :
    - service zabbix-server stop
    - rm -Rf /etc/apt/sources.list.d/zabbix.list
    - wget https://repo.zabbix.com/zabbix/7.0/d...bian12_all.deb
    - apt-get update
    - apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    it doesn't want to update mysql and zabbix agent.
    Click image for larger version  Name:	image.png Views:	0 Size:	34.4 KB ID:	485710​
    I tried :
    - sudo apt update
    - apt list --upagradable
    - sudo apt install -> error.
    IDK what is packages 1:5.4.12-1+debian11 ?? 1:7.0.0 , 1:6.0.18-1 and why debian 11 ?
    Click image for larger version  Name:	image.png Views:	0 Size:	112.6 KB ID:	485711​
    So i'm blocked.
    Click image for larger version  Name:	image.png Views:	0 Size:	13.2 KB ID:	485713​​
    thx in advance.
    Kind regards
  • Answer selected by Alrightbabyboy at 15-06-2024, 19:59.
    Markku
    • Sep 2018
    • 1786
    Your Debian seems to be 11 (bullseye), not 12 (bookworm). First you need to upgrade Debian to 12 as there is no Zabbix 7.0 server for 11.
    My Debian upgrade process for the reference (remember backups, and YMMV):
    change bullseye to bookworm in /etc/apt/sources.list
    sudo apt update
    sudo apt upgrade --without-new-pkgs
    sudo apt full-upgrade
    sudo reboot
    sudo apt install zabbix-server-mysql (...)
    Markku
    • Markku
      • Sep 2018
      • 1786
      sudo apt update
      sudo reboot
      Markku
      • Alrightbabyboy
        • Jun 2023
        • 48
        Thx for the answer.
        I upgraded the debian version to Bookworm.
