IOT and Mobus monitoring
  • nczaw
    • Sep 2023
    • 31
    Hi all,
    I want to monitor for temp and fire alarm with IOT. Then IOT will send all data to Mobus. So it's possible to monitor with zabbix for this Mobus or IOT direct ? If yes which brand of IOT shoud I use ? to easy to monitor with zabbix.
    Thanks all
  • Hamardaban
    • May 2019
    • 2714
    RTFM https://www.zabbix.com/documentation.../modbus_plugin
    • nczaw
      • Sep 2023
      • 31
      As I know Modbus can integrated with zabbix from zabbix-agent2 right. Now I already installed Zabbix Agent2 in my Zabbix server and what kind of peramater I need to configure for this agent.config file ? What kind of informations did I need to know from Modbus side ?
      Thanks you all
      • Hamardaban
        • May 2019
        • 2714
        and again! documentation is your friend! There is a search in it - use it.
