Too much Proxy configuration update logs
  • markfree
    • Apr 2019
    • 875
    Whenever an active Proxy retrieves configuration data from the Zabbix Server, the Server logs this information.
    I have an environment with a proxy where the "ProxyConfigFrequency" is set to 60.
    This creates a new line record in the Server log every minute.
    124432:20240620:214139.515 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124431:20240620:214239.661 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124434:20240620:214339.794 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124432:20240620:214439.929 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    124431:20240620:214540.076 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124430:20240620:214640.214 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124431:20240620:214740.349 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124433:20240620:214840.490 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124431:20240620:214940.630 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    124433:20240620:215040.767 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124432:20240620:215140.912 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124431:20240620:215241.057 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124432:20240620:215341.186 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    124431:20240620:215441.324 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124434:20240620:215541.466 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124430:20240620:215641.605 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124433:20240620:215741.735 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 211 with compression ratio 2.0
    124434:20240620:215841.886 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    124433:20240620:215942.033 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    124433:20240620:220042.181 sending configuration data to proxy "PROXY" at "proxy.ip", datalen 428, bytes 212 with compression ratio 2.0
    I already increased the configuration update frequency to 60 seconds, which is good enough for me, but I find the log writing frequency a bit too high.
    Increasing the frequency would reduce the log writes, but that would undermine the benefit of faster Proxy updates.
    So is anyone doing anything about all this logging?
