When clicking on a Host in Problems, can you have a script that opens "URL A"?
  • brettr
    • Jun 2024
    I'm trying to create a script that will open the URL of a host assigned to the URL A section to the scripts or other another way when in the problems tab.
    • 5002
    https://www.zabbix.com/documentation...iggers/trigger
    Menu entry URL If not empty, the URL entered here (up to 2048 characters) is available as a link in the event menu in several frontend locations, for example, when clicking on the problem name in Monitoring → Problems or Problems dashboard widget.
    The same set of macros is supported as in the trigger name, plus {EVENT.ID}, {HOST.ID} and {TRIGGER.ID}. Note: user macros with secret values will not be resolved in the URL.
    So you can easily add https://{HOST.NAME}/some/path there...
