After adding an SNMP item - receive error "get[OID]" contains unsupported parameters
  • jburysom
    • Jun 2024
    • 16
    Hello there,
    I’m running zabbix server version 6.4.14.1. I am following the documentation from “2 SNMP Agent” to add an item for SNMP monitoring in zabbix. Below is the URL.
    https://www.zabbix.com/documentation...itemtypes/snmp
    I created an SNMP item for a Liebert PDU device from information gathered via snmpwalk and snmpget. Below is the output of the the OIDs I want to add from snmpwalk and snmpget.
    After adding the OID ".1.3.6.1.4.1.476.1.42.3.8.40.20.1.130.1.1" per the documentation, I receive the following error in the “info” column of the new item for the device.
    OID "get[.1.3.6.1.4.1.476.1.42.3.8.40.20.1.130.1.1]" contains unsupported parameters.
    Any ideas on what I may be doing wrong or any help would be greatly appreciated. Thanks.
    SNMPWALK:
    # snmpwalk -v 1 -c LiebertEM 10.90.xxx.xxx 1.3.6.1.4.1
    SNMPv2-SMI::enterprises.476.1.42.3.8.40.20.1.130.1.1 = Gauge32: 229
    SNMPv2-SMI::enterprises.476.1.42.3.8.40.20.1.130.1.2 = Gauge32: 296
    SNMPv2-SMI::enterprises.476.1.42.3.8.40.20.1.130.1.3 = Gauge32: 113
    # snmpwalk -v 1 -c LiebertEM 10.90.xxx.xxx 1.3.6.1.4.1.476
    LIEBERT-GP-PDU-MIB::lgpPduRbEntryEcHundredths.1.1 = Gauge32: 230 0.01 Amp-AC-RMS
    LIEBERT-GP-PDU-MIB::lgpPduRbEntryEcHundredths.1.2 = Gauge32: 285 0.01 Amp-AC-RMS
    LIEBERT-GP-PDU-MIB::lgpPduRbEntryEcHundredths.1.3 = Gauge32: 112 0.01 Amp-AC-RMS
    SNMPGET:
    # snmpget -v 1 -c LiebertEM -On 10.90.xxx.xxx SNMPv2-SMI::enterprises.476.1.42.3.8.40.20.1.130.1.1
    .1.3.6.1.4.1.476.1.42.3.8.40.20.1.130.1.1 = Gauge32: 228 0.01 Amp-AC-RMS
    # snmpget -v 1 -c LiebertEM -On 10.90.xxx.xxx LIEBERT-GP-PDU-MIB::lgpPduRbEntryEcHundredths.1.1
    .1.3.6.1.4.1.476.1.42.3.8.40.20.1.130.1.1 = Gauge32: 230 0.01 Amp-AC-RMS
  • Answer selected by jburysom at 01-07-2024, 19:58.
    Markku
    • Sep 2018
    • 1784
    get[] is not available in Zabbix 6.4, it is not mentioned in the 6.4 SNMP page you linked. Instead, it was introduced in 7.0:
    In 6.4 you need to use the old syntax with just the OID, no other keywords.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • jburysom
        • Jun 2024
        • 16
        Markku,
        That did the trick. I've been looking at this for a couple days now - and apparently looking at the incorrect documentation - Ugh... Thanks for your response, much appreciated.
        John
