TimescaleDB problems after Update from 7.0.0 to 7.0.1
  • Daniel4711
    • Jul 2014
    • 127
    Hello everyone,
    Yesterday I updated from Zabbix 7.0.0 to 7.0.1.
    I restarted the server today because I noticed that the dashboard was still showing version 7.0.0.
    Shortly afterwards, I noticed that the dashboard was showing connection problems to the server.
    Apparently there are problems with the TimeScaleDB configuration and the auditlog table.
    When installing Zabbix 7, I followed the instructions provided by Zabbix. Unfortunately I am not a database expert, so I hope someone has a hint for me!
    OS/Software information:
    Debian 12 Bookworm
    Postgresql: 16.3
    Timescaledb: 2.14.2
    apt-get upgrade history:
    Start-Date: 2024-07-23  10:03:03
    Commandline: apt-get upgrade
    Upgrade: zabbix-sql-scripts:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent2-plugin-mongodb:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-server-pgsql:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-apache-conf:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent2-plugin-ember-plus:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent2-plugin-mssql:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-get:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent2:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-agent2-plugin-postgresql:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12), zabbix-frontend-php:amd64 (1:7.0.0-1+debian12, 1:7.0.1-1+debian12)
    End-Date: 2024-07-23  10:03:14
    Since the restart this morning, the service crashes and restarts every 2-3 minutes.
    Always with the previously non-existent Timescaledb error message
    First 7.0.1 Log Entry including Errors
    2129436:20240724:071115.633 Zabbix Server stopped. Zabbix 7.0.0 (revision 49955f1fb5c).
    494003:20240724:071125.507 Starting Zabbix Server. Zabbix 7.0.1 (revision 0543fbe4af6).
    494003:20240724:071125.664 starting automatic database upgrade
    494003:20240724:071125.710 completed 50% of database upgrade
    494003:20240724:071129.744 slow query: 4.020465 sec, "create index auditlog_4 on auditlog (recordsetid)"
    494003:20240724:071129.746 completed 100% of database upgrade​
    494072:20240724:071131.980 Unexpected TimescaleDB configuration: the auditlog table does not have compress_created_before compression policy
    494102:20240724:071321.367 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
    The Full Log between first start and first crash:
    494003:20240724:071125.508 ****** Enabled features ******
    494003:20240724:071125.508 SNMP monitoring:           YES
    494003:20240724:071125.508 IPMI monitoring:           YES
    494003:20240724:071125.508 Web monitoring:            YES
    494003:20240724:071125.508 VMware monitoring:         YES
    494003:20240724:071125.508 SMTP authentication:       YES
    494003:20240724:071125.508 ODBC:                      YES
    494003:20240724:071125.508 SSH support:               YES
    494003:20240724:071125.508 IPv6 support:              YES
    494003:20240724:071125.508 TLS support:               YES
    494003:20240724:071125.508 ******************************
    494003:20240724:071125.508 using configuration file: /etc/zabbix/zabbix_server.conf
    494003:20240724:071125.664 current database version (mandatory/optional): 07000000/07000000
    494003:20240724:071125.664 required mandatory version: 07000000
    494003:20240724:071125.664 optional patches were found
    [B]494003:20240724:071125.664 starting automatic database upgrade
    494003:20240724:071129.746 completed 100% of database upgrade[/B]
    494003:20240724:071129.748 database upgrade fully completed
    494056:20240724:071129.822 starting HA manager
    494056:20240724:071129.892 HA manager started in active mode
    494003:20240724:071129.907 server #0 started [main process]
    494058:20240724:071129.908 server #1 started [service manager #1]
    494059:20240724:071129.915 server #2 started [configuration syncer #1]
    494067:20240724:071131.636 server #6 started [alerter #3]
    494068:20240724:071131.637 server #7 started [preprocessing manager #1]
    494069:20240724:071131.637 server #8 started [lld manager #1]
    494070:20240724:071131.638 server #9 started [lld worker #1]
    494071:20240724:071131.639 server #10 started [lld worker #2]
    494079:20240724:071131.641 server #17 started [history syncer #2]
    494066:20240724:071131.642 server #5 started [alerter #2]
    494065:20240724:071131.643 server #4 started [alerter #1]
    494077:20240724:071131.643 server #15 started [discovery manager #1]
    494078:20240724:071131.644 server #16 started [history syncer #1]
    494072:20240724:071131.645 server #11 started [housekeeper #1]
    494064:20240724:071131.646 server #3 started [alert manager #1]
    494081:20240724:071131.647 server #18 started [history syncer #3]
    494074:20240724:071131.647 server #13 started [http poller #1]
    494082:20240724:071131.648 server #19 started [history syncer #4]
    494073:20240724:071131.650 server #12 started [timer #1]
    494085:20240724:071131.652 server #21 started [proxy poller #1]
    494075:20240724:071131.657 server #14 started [browser poller #1]
    494097:20240724:071131.671 server #24 started [vmware collector #2]
    494098:20240724:071131.671 server #25 started [task manager #1]
    494096:20240724:071131.672 server #23 started [vmware collector #1]
    494099:20240724:071131.674 server #26 started [poller #1]
    494083:20240724:071131.678 server #20 started [escalator #1]
    494100:20240724:071131.680 server #27 started [poller #2]
    494092:20240724:071131.682 server #22 started [self-monitoring #1]
    494103:20240724:071131.703 server #30 started [poller #5]
    494104:20240724:071131.705 server #31 started [unreachable poller #1]
    494105:20240724:071131.706 server #32 started [trapper #1]
    494101:20240724:071131.707 server #28 started [poller #3]
    494106:20240724:071131.714 server #33 started [trapper #2]
    494102:20240724:071131.715 server #29 started [poller #4]
    494111:20240724:071131.724 server #35 started [trapper #4]
    494112:20240724:071131.726 server #36 started [trapper #5]
    494110:20240724:071131.729 server #34 started [trapper #3]
    494113:20240724:071131.731 server #37 started [icmp pinger #1]
    494114:20240724:071131.737 server #38 started [alert syncer #1]
    494115:20240724:071131.781 server #39 started [history poller #1]
    494123:20240724:071131.784 server #40 started [history poller #2]
    494124:20240724:071131.785 server #41 started [history poller #3]
    494125:20240724:071131.787 server #42 started [history poller #4]
    494126:20240724:071131.791 server #43 started [history poller #5]
    494077:20240724:071131.825 for a discovery process with 5 workers, the user limit of 1024 file descriptors is insufficient. The maximum number of concurrent checks per worker has been reduced to 122
    494134:20240724:071131.836 server #46 started [odbc poller #1]
    494133:20240724:071131.862 server #45 started [trigger housekeeper #1]
    494132:20240724:071131.863 server #44 started [availability manager #1]
    494141:20240724:071131.877 server #49 started [agent poller #2]
    494142:20240724:071131.878 server #50 started [snmp poller #1]
    494143:20240724:071131.879 server #51 started [configuration syncer worker #1]
    494144:20240724:071131.879 server #52 started [internal poller #1]
    494136:20240724:071131.882 server #47 started [http agent poller #1]
    494137:20240724:071131.883 server #48 started [agent poller #1]
    494141:20240724:071131.898 thread started
    494150:20240724:071131.899 server #53 started [proxy group manager #1]
    494142:20240724:071131.904 thread started
    494136:20240724:071131.905 thread started
    494137:20240724:071131.905 thread started
    [B]494072:20240724:071131.980 Unexpected TimescaleDB configuration: the auditlog table does not have compress_created_before compression policy[/B]
    494150:20240724:071132.006 Proxy "zabbix_proxy1" changed state from unknown to online
    494110:20240724:071132.194 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 2284639, bytes 205071 with compression ratio 11.1
    494068:20240724:071132.247 [3] thread started [preprocessing worker #3]
    494068:20240724:071132.247 [2] thread started [preprocessing worker #2]
    494068:20240724:071132.247 [1] thread started [preprocessing worker #1]
    494077:20240724:071132.291 thread started [discovery worker #1]
    494077:20240724:071132.292 thread started [discovery worker #3]
    494077:20240724:071132.292 thread started [discovery worker #4]
    494077:20240724:071132.292 thread started [discovery worker #2]
    494077:20240724:071132.292 thread started [discovery worker #5]
    494141:20240724:071141.883 Zabbix agent item "net.tcp.service[{$TCP_SERVICE},,{$TCP_PORT}]" on host "KG-MS-SM-CRM-IL" failed: first network error, wait for 15 seconds
    494106:20240724:071142.560 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494105:20240724:071144.841 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 2284639, bytes 205071 with compression ratio 11.1
    494112:20240724:071155.196 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 201 with compression ratio 2.1
    494141:20240724:071156.882 resuming Zabbix agent checks on host "KG-MS-SM-CRM-IL": connection restored
    494106:20240724:071205.248 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494078:20240724:071206.602 item "ka-wt-sm-03.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494078:20240724:071207.594 item "ka-wt-sm-08.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494078:20240724:071208.620 item "ka-wt-sm-02.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494078:20240724:071211.645 item "ka-wt-sm-05.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494111:20240724:071215.302 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494081:20240724:071220.359 item "vcenter:vmware.eventlog[{$VMWARE.URL},skip]" became supported
    494105:20240724:071225.344 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 201 with compression ratio 2.1
    494111:20240724:071235.392 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494078:20240724:071237.074 item "ka-wt-sm-08.domain.tld:system.net.uptime[sysUpTime.0]" became supported
    494078:20240724:071238.142 item "ka-wt-sm-02.domain.tld:system.net.uptime[sysUpTime.0]" became supported
    494078:20240724:071239.154 item "ka-wt-sm-19.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494141:20240724:071239.883 Zabbix agent item "net.tcp.service[{$TCP_SERVICE},,{$TCP_PORT}]" on host "KG-MS-SM-CRM-LV" failed: first network error, wait for 15 seconds
    494141:20240724:071242.883 Zabbix agent item "net.tcp.service[{$TCP_SERVICE},,{$TCP_PORT}]" on host "KG-MS-SM-CRM-IT" failed: first network error, wait for 15 seconds
    494111:20240724:071245.445 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494106:20240724:071255.490 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 424, bytes 202 with compression ratio 2.1
    494141:20240724:071257.884 resuming Zabbix agent checks on host "KG-MS-SM-CRM-IT": connection restored
    494141:20240724:071257.884 resuming Zabbix agent checks on host "KG-MS-SM-CRM-LV": connection restored
    494112:20240724:071305.534 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 425, bytes 203 with compression ratio 2.1
    494078:20240724:071306.799 item "ka-wt-sm-03.domain.tld:system.net.uptime[sysUpTime.0]" became supported
    494078:20240724:071307.758 item "ka-wt-sm-08.domain.tld:system.net.uptime[sysUpTime.0]" became not supported: snmp_fix_pdu(): cannot fix PDU object.
    494112:20240724:071315.578 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 425, bytes 203 with compression ratio 2.1
    [B]494102:20240724:071321.367 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...[/B]
    [B]494102:20240724:071321.367 ====== Fatal information: ======[/B]
    494102:20240724:071321.367 Program counter: 0x55d9729ab5a1
    494102:20240724:071321.367 === Registers: ===
    494102:20240724:071321.367 r8      =     7ffc17a6e73c =      140720705300284 =      140720705300284
    494102:20240724:071321.367 r9      =                0 =                    0 =                    0
    494102:20240724:071321.367 r10     = 1b5eff55755df8b2 =  1972294429341251762 =  1972294429341251762
    494102:20240724:071321.367 r11     =     55d9736af574 =       94392432653684 =       94392432653684
    494102:20240724:071321.367 r12     =                0 =                    0 =                    0
    494102:20240724:071321.367 r13     =                2 =                    2 =                    2
    494102:20240724:071321.368 r14     =     55d9736ca490 =       94392432764048 =       94392432764048
    494102:20240724:071321.368 r15     =     7f9a4d87e570 =      140300702442864 =      140300702442864
    494102:20240724:071321.368 rdi     =                0 =                    0 =                    0
    494102:20240724:071321.368 rsi     =     7f9a4d87e570 =      140300702442864 =      140300702442864
    494102:20240724:071321.368 rbp     =                0 =                    0 =                    0
    494102:20240724:071321.368 rbx     =     7ffc17a70fb0 =      140720705310640 =      140720705310640
    494102:20240724:071321.368 rdx     =         66a08d34 =           1721797940 =           1721797940
    494102:20240724:071321.368 rax     =          18749d9 =             25643481 =             25643481
    494102:20240724:071321.368 rcx     =               3d =                   61 =                   61
    494102:20240724:071321.368 rsp     =     7ffc17a6e700 =      140720705300224 =      140720705300224
    494102:20240724:071321.368 rip     =     55d9729ab5a1 =       94392419005857 =       94392419005857
    494102:20240724:071321.368 efl     =            10246 =                66118 =                66118
    494102:20240724:071321.368 csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
    494102:20240724:071321.368 err     =                4 =                    4 =                    4
    494102:20240724:071321.368 trapno  =                e =                   14 =                   14
    494102:20240724:071321.368 oldmask =                0 =                    0 =                    0
    494102:20240724:071321.368 cr2     =                0 =                    0 =                    0
    494102:20240724:071321.368 === Backtrace: ===
    494102:20240724:071321.503 15: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](zbx_backtrace+0x3b) [0x55d972c4089b]
    494102:20240724:071321.503 14: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](zbx_log_fatal_info+0x17d) [0x55d972c40b0d]
    494102:20240724:071321.503 13: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](+0x3c41c6) [0x55d972c411c6]
    494102:20240724:071321.503 12: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f9a624e2050]
    494102:20240724:071321.504 11: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](check_vcenter_eventlog+0x301) [0x55d9729ab5a1]
    494102:20240724:071321.504 10: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](get_value_simple+0x256) [0x55d97299c526]
    494102:20240724:071321.504 9: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](zbx_check_items+0x33b) [0x55d972997cbb]
    494102:20240724:071321.504 8: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](+0x11b321) [0x55d972998321]
    494102:20240724:071321.504 7: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](zbx_poller_thread+0x33d) [0x55d97299931d]
    494102:20240724:071321.504 6: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](zbx_thread_start+0x20) [0x55d972b752f0]
    494102:20240724:071321.504 5: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](+0xcec16) [0x55d97294bc16]
    494102:20240724:071321.504 4: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](MAIN_ZABBIX_ENTRY+0xe55) [0x55d97294d855]
    494102:20240724:071321.504 3: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](main+0x37e) [0x55d972941b2e]
    494102:20240724:071321.504 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f9a624cd24a]
    494102:20240724:071321.504 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f9a624cd305]
    494102:20240724:071321.504 0: /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000019 sec, getting values](_start+0x21) [0x55d972948b81]
    494102:20240724:071321.504 === Memory map: ===
    494102:20240724:071321.504 55d97287d000-55d97293a000 r--p 00000000 08:01 1839703                    /usr/sbin/zabbix_server
    494102:20240724:071321.504 55d97293a000-55d972c74000 r-xp 000bd000 08:01 1839703                    /usr/sbin/zabbix_server
    494102:20240724:071321.504 55d972c74000-55d972da8000 r--p 003f7000 08:01 1839703                    /usr/sbin/zabbix_server
    494102:20240724:071321.504 55d972da8000-55d972dac000 r--p 0052b000 08:01 1839703                    /usr/sbin/zabbix_server
    494102:20240724:071321.504 55d972dac000-55d972eab000 rw-p 0052f000 08:01 1839703                    /usr/sbin/zabbix_server
    494102:20240724:071321.504 55d972eab000-55d972ebd000 rw-p 00000000 00:00 0
    494102:20240724:071321.504 55d97360f000-55d973651000 rw-p 00000000 00:00 0                          [heap]
    494102:20240724:071321.504 55d973651000-55d9736da000 rw-p 00000000 00:00 0                          [heap]
    494102:20240724:071321.504 55d9736da000-55d973ae8000 rw-p 00000000 00:00 0                          [heap]
    494102:20240724:071321.504 7f9a4b000000-7f9a4b340000 r--p 00000000 08:01 1870991                    /usr/lib/locale/locale-archive
    494102:20240724:071321.504 7f9a4b43e000-7f9a4b47e000 rw-s 00000000 00:01 32807                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a4b47e000-7f9a4b87e000 rw-s 00000000 00:01 32806                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a4b87e000-7f9a4d87e000 rw-s 00000000 00:01 32805                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a4d87e000-7f9a4e07e000 rw-s 00000000 00:01 32804                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a4e07e000-7f9a4e08c000 rw-s 00000000 00:01 32803                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a4e08c000-7f9a5e08c000 rw-s 00000000 00:01 32802                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a5e08c000-7f9a5e48c000 rw-s 00000000 00:01 32801                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a5e48c000-7f9a5e88c000 rw-s 00000000 00:01 32800                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a5e88c000-7f9a5f88c000 rw-s 00000000 00:01 32799                      /SYSV00000000 (deleted)
    494102:20240724:071321.504 7f9a5f88c000-7f9a5f88f000 r--p 00000000 08:01 1835428                    /usr/lib/x86_64-linux-gnu/libcap.so.2.66
    494102:20240724:071321.504 7f9a5f88f000-7f9a5f894000 r-xp 00003000 08:01 1835428                    /usr/lib/x86_64-linux-gnu/libcap.so.2.66
    494102:20240724:071321.504 7f9a5f894000-7f9a5f896000 r--p 00008000 08:01 1835428                    /usr/lib/x86_64-linux-gnu/libcap.so.2.66
    494102:20240724:071321.504 7f9a5f896000-7f9a5f897000 r--p 0000a000 08:01 1835428                    /usr/lib/x86_64-linux-gnu/libcap.so.2.66
    494102:20240724:071321.504 7f9a5f897000-7f9a5f898000 rw-p 0000b000 08:01 1835428                    /usr/lib/x86_64-linux-gnu/libcap.so.2.66
    494102:20240724:071321.504 7f9a5f898000-7f9a5f89f000 r--p 00000000 08:01 1836478                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    494102:20240724:071321.504 7f9a5f89f000-7f9a5f8d3000 r-xp 00007000 08:01 1836478                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    494102:20240724:071321.504 7f9a5f8d3000-7f9a5f8e3000 r--p 0003b000 08:01 1836478                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    494102:20240724:071321.504 7f9a5f8e3000-7f9a5f8e7000 r--p 0004b000 08:01 1836478                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    494102:20240724:071321.504 7f9a5f8e7000-7f9a5f8e8000 rw-p 0004f000 08:01 1836478                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    494102:20240724:071321.504 7f9a5f8e8000-7f9a5f8f3000 r--p 00000000 08:01 1835472                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    494102:20240724:071321.504 7f9a5f8f3000-7f9a5f950000 r-xp 0000b000 08:01 1835472                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    494102:20240724:071321.504 7f9a5f950000-7f9a5f967000 r--p 00068000 08:01 1835472                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    494102:20240724:071321.504 7f9a5f967000-7f9a5f968000 r--p 0007f000 08:01 1835472                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    494102:20240724:071321.504 7f9a5f968000-7f9a5f969000 rw-p 00080000 08:01 1835472                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    ...snip, because of to many characters in this post...
    494102:20240724:071321.507 7f9a63477000-7f9a63479000 rw-p 00032000 08:01 1837201                    /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    494102:20240724:071321.507 7ffc17a1a000-7ffc17a7b000 rw-p 00000000 00:00 0                          [stack]
    494102:20240724:071321.507 7ffc17ada000-7ffc17ade000 r--p 00000000 00:00 0                          [vvar]
    494102:20240724:071321.507 7ffc17ade000-7ffc17ae0000 r-xp 00000000 00:00 0                          [vdso]
    494102:20240724:071321.507 ================================
    494102:20240724:071321.507 Please consider attaching a disassembly listing to your bug report.
    494102:20240724:071321.507 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    [B]494003:20240724:071321.520 One child process died (PID:494102,exitcode/signal:1). Exiting ...[/B]
    494056:20240724:071321.520 HA manager has been paused
    zabbix_server [494003]: Error waiting for process with PID 494102: [10] No child processes
    494056:20240724:071321.637 HA manager has been stopped
    494003:20240724:071321.668 syncing history data...
    494003:20240724:071321.672 syncing history data... 100.000000%
    494003:20240724:071321.672 syncing history data done
    494003:20240724:071321.672 syncing trend data...
    494003:20240724:071324.694 syncing trend data done
    494003:20240724:071324.715 Zabbix Server stopped. Zabbix 7.0.1 (revision 0543fbe4af6).
    494742:20240724:071334.802 Starting Zabbix Server. Zabbix 7.0.1 (revision 0543fbe4af6).
    494742:20240724:071334.802 ****** Enabled features ******
    494742:20240724:071334.802 SNMP monitoring:           YES
    494742:20240724:071334.802 IPMI monitoring:           YES
    494742:20240724:071334.802 Web monitoring:            YES
    494742:20240724:071334.802 VMware monitoring:         YES
    494742:20240724:071334.802 SMTP authentication:       YES
    494742:20240724:071334.802 ODBC:                      YES
    494742:20240724:071334.802 SSH support:               YES
    494742:20240724:071334.802 IPv6 support:              YES
    494742:20240724:071334.802 TLS support:               YES
    494742:20240724:071334.802 ******************************
    494742:20240724:071334.802 using configuration file: /etc/zabbix/zabbix_server.conf
    494742:20240724:071334.842 current database version (mandatory/optional): 07000000/07000002
    494742:20240724:071334.842 required mandatory version: 07000000
    494744:20240724:071334.847 starting HA manager
    494744:20240724:071334.872 HA manager started in active mode
    494742:20240724:071334.873 server #0 started [main process]
    494746:20240724:071334.873 server #1 started [service manager #1]
    494747:20240724:071334.874 server #2 started [configuration syncer #1]
    494755:20240724:071335.816 server #6 started [alerter #3]
    494756:20240724:071335.817 server #7 started [preprocessing manager #1]
    494754:20240724:071335.818 server #5 started [alerter #2]
    494758:20240724:071335.818 server #9 started [lld worker #1]
    494762:20240724:071335.819 server #13 started [http poller #1]
    494759:20240724:071335.820 server #10 started [lld worker #2]
    494766:20240724:071335.821 server #16 started [history syncer #1]
    494753:20240724:071335.822 server #4 started [alerter #1]
    494757:20240724:071335.823 server #8 started [lld manager #1]
    494760:20240724:071335.823 server #11 started [housekeeper #1]
    494769:20240724:071335.823 server #19 started [history syncer #4]
    494761:20240724:071335.825 server #12 started [timer #1]
    494764:20240724:071335.826 server #15 started [discovery manager #1]
    494752:20240724:071335.827 server #3 started [alert manager #1]
    494767:20240724:071335.827 server #17 started [history syncer #2]
    494763:20240724:071335.828 server #14 started [browser poller #1]
    494768:20240724:071335.829 server #18 started [history syncer #3]
    494771:20240724:071335.829 server #20 started [escalator #1]
    494780:20240724:071335.843 server #22 started [self-monitoring #1]
    494783:20240724:071335.850 server #25 started [task manager #1]
    494784:20240724:071335.851 server #26 started [poller #1]
    494785:20240724:071335.852 server #27 started [poller #2]
    494781:20240724:071335.853 server #23 started [vmware collector #1]
    494786:20240724:071335.853 server #28 started [poller #3]
    494782:20240724:071335.854 server #24 started [vmware collector #2]
    494756:20240724:071335.856 [1] thread started [preprocessing worker #1]
    494756:20240724:071335.856 [2] thread started [preprocessing worker #2]
    494756:20240724:071335.856 [3] thread started [preprocessing worker #3]
    494787:20240724:071335.859 server #29 started [poller #4]
    494773:20240724:071335.877 server #21 started [proxy poller #1]
    494793:20240724:071335.881 server #30 started [poller #5]
    494795:20240724:071335.882 server #32 started [trapper #1]
    494796:20240724:071335.883 server #33 started [trapper #2]
    494794:20240724:071335.887 server #31 started [unreachable poller #1]
    494797:20240724:071335.887 server #34 started [trapper #3]
    494798:20240724:071335.889 server #35 started [trapper #4]
    494799:20240724:071335.898 server #36 started [trapper #5]
    494808:20240724:071335.948 server #37 started [icmp pinger #1]
    494810:20240724:071335.949 server #39 started [history poller #1]
    494815:20240724:071335.965 server #43 started [history poller #5]
    494814:20240724:071335.967 server #42 started [history poller #4]
    494813:20240724:071335.968 server #41 started [history poller #3]
    494819:20240724:071335.969 server #47 started [http agent poller #1]
    494812:20240724:071335.982 server #40 started [history poller #2]
    494764:20240724:071335.982 for a discovery process with 5 workers, the user limit of 1024 file descriptors is insufficient. The maximum number of concurrent checks per worker has been reduced to 122
    494809:20240724:071335.997 server #38 started [alert syncer #1]
    494816:20240724:071335.999 server #44 started [availability manager #1]
    494820:20240724:071336.002 server #48 started [agent poller #1]
    494821:20240724:071336.003 server #49 started [agent poller #2]
    494822:20240724:071336.003 server #50 started [snmp poller #1]
    494817:20240724:071336.007 server #45 started [trigger housekeeper #1]
    494818:20240724:071336.010 server #46 started [odbc poller #1]
    494819:20240724:071336.011 thread started
    494820:20240724:071336.012 thread started
    494821:20240724:071336.012 thread started
    494822:20240724:071336.013 thread started
    494833:20240724:071336.013 server #51 started [configuration syncer worker #1]
    494764:20240724:071336.014 thread started [discovery worker #1]
    494764:20240724:071336.014 thread started [discovery worker #2]
    494764:20240724:071336.014 thread started [discovery worker #5]
    494764:20240724:071336.014 thread started [discovery worker #4]
    494834:20240724:071336.014 server #52 started [internal poller #1]
    494841:20240724:071336.017 server #53 started [proxy group manager #1]
    494764:20240724:071336.055 thread started [discovery worker #3]
    [B]494760:20240724:071336.113 Unexpected TimescaleDB configuration: the auditlog table does not have compress_created_before compression policy[/B]
    494841:20240724:071336.176 Proxy "zabbix_proxy1" changed state from unknown to online
    494797:20240724:071336.578 sending configuration data to proxy "zabbix_proxy1" at "10.3.11.31", datalen 2284639, bytes 205071 with compression ratio 11.1
    494766:20240724:071337.905 item "ka-wt-sm-08.domain.tld:system.net.uptime[sysUpTime.0]" became supported
    Many thanks for any advice!
  • Answer selected by Daniel4711 at 24-07-2024, 12:01.
    Markku
    • Sep 2018
    • 1784
    Maybe these:
    https://support.zabbix.com/browse/ZBX-24889 = VMware poller crash (to be fixed in 7.0.2)
    https://www.zabbix.com/documentation...grade-from-7.0 = known issue "Server crash with PostgreSQL/TimescaleDB after upgrade from 7.0"
    Markku
    • Markku
      • Sep 2018
      • 1784
      Maybe these:
      Markku
      • Daniel4711
        • Jul 2014
        • 127
        Thanks for the answer!
        However, I'm still on the stable path and can't find any information on how to switch to unstable/rc.
        My zabbix.list already looks like in the documentation.
        # Zabbix main repository
        deb https://repo.zabbix.com/zabbix/7.0/debian bookworm main
        deb-src https://repo.zabbix.com/zabbix/7.0/debian bookworm main
        zabbix_server --version
        zabbix_server (Zabbix) 7.0.1
        Revision 0543fbe4af6 22 July 2024, compilation time: Jul 22 2024 07:14:13
        • Markku
          • Sep 2018
          • 1784
          There isn't a 7.0.2 rc version available yet, and there aren't prebuilt packages for patch rc versions (like 7.0.2rc1; the link you provided seems to refer to major/minor versions like 6.5 = 7.0alpha/beta/rc, but there aren't any available yet for 7.2), so I think the only way to get the VMware poller thing fixed is to follow the issue and compile the server from sources when the fix is available. But on the other hand, since/if the issue is severe, maybe they'll push 7.0.2 out sooner.
          Markku
          • Daniel4711
            • Jul 2014
            • 127
            Thank you again.
            I took care of the TimescaleDB issue first and after executing the commands I found that the system still crashes.
            Unfortunately, I only took care of the Vmware issue after your 2nd message.
            I have disabled the Vmware collectors on the server and proxy, deactivated the hosts and will wait and see.
            So far the server is stable - I can do without Vmware for the time being!
            Thank you so much, you made my day!
