Proxmox Ve Template with HTTP Agent and Query fileds
  • galvy
    • Jun 2020
    • 19
    #16
    Originally posted by CharlieRoot
    I can confirm we see the same behaviour. We do not use Query Fields but we see the ?= in the URL causing a 501 on our templates. I just updated to 7.0.2 this morning to see if that would resolve it, but that is sadly not the case.
    Response code "501" did not match any of the required status codes "200" HTTP/1.1 301 Moved Permanently Location: https://xxxxxxx/Chassis/1/Power/?=/
    After several days of testing, I have realized that the problem is caused only by the "item test", with test button zabbix add always "?="
    If I let Zabbix run without interference, everything works correctly.
    The issue on the Proxmox side is due to a misconfiguration on my part.
    Thank you all for the help.
    • CharlieRoot
      • Oct 2020
      • 15
      #17
      Sadly this is not the case in our situation. We see /?= in all requests from the HTTP agent.
