Aggregation of Several Components
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    Is it possible to aggregate several components into one number? For example my OPNsense firewalls do not show one cpu utilization %. They show nice time, user time, interrupt time, and system time %. I would like to add these up and show them as one cpu utilization %.
    Thanks,
    Steve
  • markfree
    • Apr 2019
    • 875
    If you have multiple values of the same unit, you can probably aggregate them with a calculated item.
    However, it's not because they have the same unit that they mean the same thing.
    So, for your example, different CPU timings, when aggregated, may not be a good metric to monitor. On the other hand, if you have individual timings per core, it makes more sense to aggregate all cores for each timing
    • stevefxp
      • Aug 2020
      • 168
      I hear ya...I just wish that cpu utilization would be the same across templates. Its very annoying that I have to go nuts trying to figure out a workaround for simple items like cpu and memory utilization.
      • markfree
        markfree commented
        The thing is, devices/systems are different. So the metrics are different for each one.
        Fortunately, Zabbix is very flexible.
