How to use Zabbix share?
  • BJD1997
    • Jan 2017
    Hello all,
    I just set up a zabbix server 2 weeks ago and tested some things like monitoring Windows servers and VMware servers but now I want to try to add the Universal Printer Template but I can't figure out how to do so. I completely new to zabbix so I don't have much experience yet and I couldn't find any info on how to add such templates.
  • SBO
    • Sep 2015
    • 226
    Download the template on the zabbix share, go on your zabbix, configuration, template and you have an import option.
    I hugely suggest you to read the Zabbix documentation if you have troubles with such a basic task ; it is very well documented, and you have tons of examples.
    • batchenr
      • Sep 2016
      • 440
      Originally posted by BJD1997
      Hello all,
      i have explained in this :
      let me know if you need more help
      • BJD1997
        • Jan 2017
        Thanks guys I figured it out
        My problem was that I used Internet Explorer and that show the code of the xml file instead of downloading it and I thought I had to make a template and put all these codes in manually but then I opened FireFox which just downloaded the file and uploaded it and it works just fine!
        Sorry for my maybe stupid question but it works now
        • BayramGrbz45
          • Sep 2020
          • 16
          Hello.
          I can no longer find your printer template that I used before. Is it possible for you to share this teplate with me?
          Thank you.
          https://web.archive.org/web/20200920...inter-template
            Zabbix share is no more. you should find related things from here https://github.com/zabbix/community-templates
