zabbix can support to call for notification
  • nczaw
    • Sep 2023
    • 31
    Hi All,
    Is it possible for Zabbix to support notifications via mobile calls when critical alerts happen? If yes, what kind of integration is needed to set up call notifications?
    Thanks in advance for your help!
  • kamil1
    • Aug 2024
    • 40
    Yes, Zabbix can support notifications via mobile calls for critical alerts, but it requires external integrations since Zabbix itself doesn't have built-in voice call functionality. You can achieve this by integrating with third-party services that provide call notifications via APIs.
    For example, you could use Twilio (see here for a reference https://www.zabbix.com/integrations/twilio).
